Nacra Rudder All In...
Nacra Rudder All Internal Bungee Mod???
ctcataman
(@ctcataman)
[#8113]
The bungee on my stick mid 80 Nacra got scuffed by the casting and broke through the cover. Rather than run the bungee from rudder to end of tiller arm, has anyone used a length of small diameter line or stsinless cable from the rudder into tje tiller arm tibe, so there is no shock cord exposed? Seems like it ought to work, even giving up a bit of eladtic cotd length. Thanks.
Posted : March 20, 2022 1:43 pm
(@carbonc)
Interesting thought John. Two questions come to mind…
1) Are you using a section of 1” tubing on the bungee between the end of the tiller tube and the rudder?
2) If you used hard cable at the rudder it seems you’d add wear to the top of the rudder where the bungee rides when the rudder is in the down position.
Posted : March 20, 2022 3:31 pm
ctcataman
(@ctcataman)
I have not used a tube over the bungees. Good idea.
Posted : March 20, 2022 4:10 pm
I wouldn’t bother. Using SS cable will quickly wear the rudder blade, you would need some sort of bushing in the blade.
If you wear bungee cover,you’ll wear line.
The 1” of tubing carbonc mentions is not to prevent bungee chafe, it serves to stop the rudder from banging against the end of the tiller tube- you can see the damage to my blade in one of the photos.
I solved this problem years ago, with very little effort, & zero cost. Here’s a couple photos from my N5.7 album. Tap the photo after opening the link to get the full size photo. I can’t figure out how to directly insert the photo from an iPad…there is no right click-“copy link location”
https://www.thebeachcats.com/pictures?g2_itemId=80972&g2_GALLERYSID=328d7e81d5da9872faca9d74eccb7cba
https://www.thebeachcats.com/pictures?g2_itemId=119562&g2_GALLERYSID=4e34608100efffe85580c8adee485a14
Edited by Edchris177 on Mar 21, 2022 - 05:19 PM.
Posted : March 21, 2022 11:11 am
ctcataman
(@ctcataman)
Thanks. Mine has the same notch cut in from up position contact. West time.
I may add a roller for the pull down line pivot
Posted : March 21, 2022 11:22 pm
ctcataman
(@ctcataman)
What size and material tube works best? I will prob run 5/16 bungee
Posted : March 24, 2022 3:25 am
tominpa
(@tominpa)
My rudder is still using the original cushion/tube. It's a little larger in diameter than the tiller arm, but not a precision part.
Posted : March 24, 2022 6:06 am
Go to your local Home Depot, Harbour Freight, or any place that has tubing, & ask for 3”. I used a clear Tube with nylon reinforcement, about the diameter of the tiller tube.
A scrap from any 1” water hose will work.
Posted : March 26, 2022 1:47 am
