Need 4" CONTOURED inspection ports ! Can't find them....
Just went online to Murray's. They still show them available. Here is the part #'s.
Product Description
Contoured 4″ hatch 2-Port Kit
Each Contoured 4″ hatch 2-Port kit includes two deck rings and two lids. The deck ring has a contoured (curved) surface for leak-free installation on a curved deck. The kit includes two ports (hatches), nylon fasteners, silicone sealant and instructions. Cat Bags are not included.
Use this page to order hatch cover kits:
#01-1164BK Black; Compare to Hobie Cat® #5352B.
#01-1164WH White; Compare to Hobie Cat® #5352W.
Contoured Port Rings:
The underside of port deck rings are contoured to approximate the symmetrical “dome” shape of decks on most Hobie Cats, NACRAs, Prindles etc. That curvature is not perfect for all catamarans, some care must be taken to shape the deck or fill/bed the ring with sealant. Distorting the ring shape to fit the hull will not work. The port will fail to seal properly.
Edited by saltlife77 on Oct 26, 2017 - 08:23 PM.
Theres a dude selling non contoured ones on ebay for super cheap. Got some and they are viking brand. They work fine for the front ports. I just used a bunch of sealant under the sides for the small gap. The ones near the dagger board and behind the rear beam its too curved and you'd have to fill the gap more or sand the port ring down and contour it yourself with a dremel or something.
Like you I couldnt really find them at a good price. West coast sailing I got some from once but their website naming is random and depending on if you search for port or hatch or whatever it brings up different products so I couldn't find them again.
I just bought a two pack "kit" of them from these folks as when I tried to purchase from Murrays they were out. Stock in the field is all that's left for now. Note, I even tried the original manufacturer, Viking, to no avail.
https://www.strictlysailinc.com/
Another potential option would be to open up the hole to 5" diameter. 5" ports are much easier to get your arm into either when doing repairs or just grabbing stuff out of the hull while on the water. My old Hobie 17 had 4" ports and my arms would always get scraped up on the inside of the ring when reaching into the hull.
How many ports are in that boat? Nacras only came with one on each hull behind the rear beam
tamumpower1 wrote: Theres a dude selling non contoured ones on ebay for super cheap. Got some and they are viking brand. They work fine for the front ports. I just used a bunch of sealant under the sides for the small gap. The ones near the dagger board and behind the rear beam its too curved and you'd have to fill the gap more or sand the port ring down and contour it yourself with a dremel or something.
MN3 wrote: west marine caries a few brands but their in store stock is not very dependable
Murrays sent customers a notice that Viking was going out of business, and offered a sale early this summer. The people that made the nice contoured ports are no longer in business as far as I know. I have treated my ports with marine paint so they won't deteriorate.
Hope you find some replacements.
HULLFLYER wrote: How many ports are in that boat? Nacras only came with one on each hull behind the rear beam
Mine has 3 per hull. One in front and behind the dagger board and one behind the rear beam. When you have a nacra as old as mine I'm pretty sure you had to have them to build the boat. It's a stringer hull so it's in 2 halves. You'd need access to finish the dagger board trunks once it was together I figure. Totally possible they were added later but all the once I've seen online have the same ports as mine. The rear one is obviously for the rudder bolts since nacra doesn't do the glassed in plate to tap into like the hobies.
- 5,940 Online
