New SX mast and Nac...
New SX mast and Nacra spinnaker pole
(@shipchips1)
[#3648]
Hey guys, I need a little help here. I just bought a H18SX mast and a Nacra spinnaker pole.
The mast has 2 harken down haul swivel cam cleats mounted at the mast base on a SS bracket what is this for? Is it for the down haul? If so why 2? Is this after market?
The spinnaker pole has a goose neck on it and I am looking for options to mount it to my cross beam.
I have a H18 with SX wings and the extra mounting plates for the cross beams.
Not the best photos but I think you can see what I am asking about.
Edited by shipchips1 on Apr 11, 2013 - 11:01 AM.
Posted : April 11, 2013 3:57 am
(@rider_55)
There are two swivel cam cleats so the downhaul can be adjusted by the crew while on the wire on either side.
Posted : April 11, 2013 4:26 am
(@shipchips1)
Do you mean while on the trapeze?
Posted : April 11, 2013 5:03 am
(@bacho)
Most nacra systems I have seen use a plate with a stud sticking out of it riveted to the beam. The pole has a plastic insert stuck into the pole that fits around the stud. You can attache the pole anyway you like, just keep in mind that you want to keep it simple to install and take apart.
Posted : April 11, 2013 5:07 am
(@rider_55)
shipchips1 wrote: Do you mean while on the trapeze?
Yes. Downhaul is a big power adjuster used often when racing especially bouy racing where every bit counts so it has to be handy.
Posted : April 11, 2013 7:02 am
(@shipchips1)
Hey thanks!
Where should I look for mounting ideas for my spin pole? I am trying to invision what the original owner of the spin pole did and I just cant see it.
Any recommendations? I don't mind doing modifications.
Edited by shipchips1 on Apr 11, 2013 - 06:41 PM.
Posted : April 11, 2013 12:40 pm
(@nacra55)
(@ricardoben)
The Hobie pole mounts like a Hobie boom since the front cross bar is a curved piece of mast you need to get the mast portion of the goose neck for a boom. HTH, Richard.
Posted : April 12, 2013 2:03 am
(@shipchips1)
Thanks guys! That will work great!
Jim
Posted : April 13, 2013 3:09 am
