P-19 Dagger Boards ...
P-19 Dagger Boards Swollen
(@lifeteammedic)
[#1610]
I have a P19 with swing down dagger boards. They are swollen near the top edge (when raised) and will not operate in the slot without a big hammer! Is there anything I can do about this besides replace? Can I sand them thinner and reglass or paint? Thanks for your suggestions!
Posted : September 20, 2010 6:27 am
(@lifeteammedic)
Bueller? Bueller? I guess no Prindle owners have ever run into this problem before?
Posted : September 26, 2010 12:10 pm
(@lifeteammedic)
Sorry as I have researched, I guess the correct term for this boat would be centerboard. They are the swing down variety and are swollen at the top of the board when in the down position. i.e. not below the waterline.
Posted : September 26, 2010 12:24 pm
(@pm)
calm down lifeteammedic,
folks are out sailing, give them a chance. Plus, Andrew is probably AFK . . . 🙂
Posted : September 26, 2010 2:32 pm
(@lifeteammedic)
That's what I am dying to go do but my centerboards are out of commission!
ok I'll bite...whats AFK?
Posted : September 27, 2010 7:11 pm
Tyler
(@tylerh)
Lifeteammedic, it mean's away from keyboard.
Posted : September 28, 2010 3:49 am
(@Anonymous 945)
Sounds like the tops are split a little and small broken pieces of glas or sand has caused them to widen. Take a knife & scrape everything out, blow it out. Then inject epoxy & put them in a vice (couple thin boards on each side). Pete
Posted : September 28, 2010 12:13 pm
(@lifeteammedic)
Interesting idea Pete. The tops are split slightly. I would assume water has gotten in there. They are a solid sandwich though. I cannot get a knife or anything in there.
Once this problem is fixed I will try to come up with a way to seal the top of that seam to prevent water from entering while stored. I may cut down some hose or PVC to snap across them while stowed to keep them dry.
Thanks for the ideas and help!
edited by: lifeteammedic, Oct 01, 2010 - 02:11 AM
Posted : September 29, 2010 11:01 pm
