P-Cat jib sheets
I have never seen one in person but I imagine that they go on the inside. Maybe take a picture of the possible attachment points and we can make an educated guess.
Also Haydukovich has a P-CAT you can try to message him. I haven't met him but he lives here in Utah as well and I might can get a message to him to check in here.
The designation "P-Cat" I know is a Pacific Catamaran. In the past I owned a Shark Catamaran. Similar lenght but wider. Close hauled the sheets went inside the stays, reach or running the sheets went outside the stays. This means you have to remove the sheets from the clew of the jib everytime you change from outside to inside the stays. I don't know if this is the case with a P-Cat? Of course one could rig 4 sheet lines but this gets a little messy. Right now the boat is some miles from me. First chance I get I'll take a picture.
- 4,084 Online
