Painting a galvaniz...
Painting a galvanized trailer
(@dmcat1)
[#1634]
My galvanized trailer for my P-16 is looking pretty bad.
Thought about painting it to make it look new again.
Any tips on what you have to do to put paint on top of
galvanized steel.
dmcat1
Posted : September 26, 2010 6:56 am
kevin horecky
(@kevin219)
what do you mean it looks bad? trailers are galvanized because they dont rust and dont need painting
Posted : September 26, 2010 8:44 am
(@dmcat1)
The bolts that are all connected to the trailer for the uprights, fenders,and mast holder have rusted and stained the galvanized rails.
This has also happened where the running lights connect to the trailer. Is there any way to clean the galvanizing to make it look newer.
dmcat1
Posted : September 26, 2010 4:32 pm
David
(@sailinagin)
Check this out....fellow used CLR with scrubbing pad on his galvanized Whaler trialer.
http://www.continuouswave.com/ubb/Forum3/HTML/008293.html
edited by: sailinagin, Sep 26, 2010 - 10:25 PM
Posted : September 26, 2010 5:16 pm
(@wwkbob)
Rust-oleum paints sells a cold galvanized(zinc)spray paint that does a great job touching up trailers. I've been using it for about 3 years and I'm very pleased with the results.
Posted : September 26, 2010 6:11 pm
Whatever you do, don't go at the rust stains with a wire brush, steel wool or similar aggressive tool. It will take off the galvanized coating pretty easy, then the entire "cleaned" are will rust, & look like POS.
Change those rusted bolts out & replace with SS bolts. If the bigger bolts are too $$ use galvanized bolts, they hold up pretty good, much better than zinc plated, way cheaper then SS
Posted : September 27, 2010 3:22 am
