painting tramp
(@gcw)
[#708]
the tramp on my prindle is a little faded the top of the hulls are bright yellow are the tramp is light/faded yellow, what if i got some of that vinyl dye that comes in a spray can you can get it at car parts stores. it sure would brighten up my cat 😕
Posted : July 2, 2009 4:22 am
Jim
 Jim
(@spray_in_the_face)
Try it out on part of the tramp, then make sure it doesn't stain you and your clothing. If you do it, post your results. I would like my tramp a little blacker instead of charcoal. 😀 GL
Posted : July 3, 2009 4:30 pm
a fading tramp could be a sign of UV damage and probably should be replaced. imagine falling through your tramp while stepping the mast...
Posted : July 4, 2009 2:40 am
yellowhulls17
(@yellowhulls17)
Crunch....broken legs and a long time on the bench from sailing...I vote to replace the tramp 😉
Seriously, try the dye on the tramp, but always be cautious and continually check the tramp for wear, cause the above can happen (winces)
Posted : July 4, 2009 4:09 am
(@gcw)
it feels strong just not as bright as the yellow top hulls. I dyed a 2x2 area white the other day the only problem to change the color is going to take a few cans.
Posted : July 4, 2009 4:25 am
Garry Routh
(@deepsees)
If the tramp is made of shelterite, it is black all the way through and it would be like trying to paint fishing line. I doubt it will allow dying and paint will most likely flake off.
Posted : July 4, 2009 10:47 am
I had a crappppppy front tramp i made from an old beat up G-Cat tramp. it was SHOT... but all i needed it was to hold a cooler and anchor.
I did spray paint it with cheap black paint... this lasted for a few months before it faded back into ugly!!!!
Posted : July 6, 2009 4:02 am
