Portable beach wheels
Are there any reasonable portable beach wheels rig? I am sailing a Whisper foiling cat; it is outrageous fun (evidence:
) , but as a beachcat it's a tad awkward to, ahem, beach 🙂
The foils come up, but stay in the trunks, as you can see here
. I need to raise the cat somehow to come safely/sanely to a beach. The rudders are ok.
I have a set of cat trax, they are large and heavy-ish. I could put them across the bows, and tie them down, but between weight and windage... meh.
Is there anything clever out there? Ideas?
You lucky bastard!
The problem is, you need the large diameter of your current Cat Trax in order to handle sand, & the height of your hulls.
I think, if you launch & return to the same place, you can leave the wheels on shore. Stop short of the beach, pull the wheels under, attach lines to your shrouds, & walk the rig up to dry land. Of course, it's much easier with two.
If you don't return to the same place, & are totally solo...(I'm thinking why?, with that hot of a rig, you should be able to find some beach babe to help), I think keeping the wheels as one piece is probably the lesser of two evils, vs splitting them.
I'm jealous, all four of my Carts are probably worth less than one of your foils. I hope someone has a brilliant solution.
Glad you like it 🙂 it's not all that expensive; I think it's about par with a regular (new) cat. If you (or any beachcats regular) drops by Miami, I'll be glad to take you out for a spin.
The problem isn't my start/end beach, it's picnic stops at beaches in the bay. Sometimes we have local informal races that involve a picnic at the destination beach. Short term, I am taking a small anchor...
- 4,409 Online
