Prindle 16 Hull concern
Is this a concern? Is hull failing (see wavy pattern on inside of hull)
https://photos.app.goo.gl/KGg8ujNttdDJ5Vr46
Posted : July 5, 2022 2:40 pm
I’m not terribly familiar with the details of the Prindle hull construction, but when Hobie hulls get wavy like that, it’s generally a sign that there is substantial delamination going on. At the very least, I would press firmly on the hull all around that area. If it’s soft, you have a problem and I would not recommend sailing the boat until the hull is repaired or replaced. Soft spots on the inside of the hull near the front crossbar can potentially lead to the bow snapping off due to bridle wire loads.
Posted : July 7, 2022 6:24 am
Forum Information
- 6,497 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
