Prindle 16 rudder rigging lines
Since mine came from Pete I recommend you listen to him. Just use good quality line you don't want to skimp here.
I did make one adjustment I like you might consider while you are redoing it though. I rigged my up line with the black rope I got from Pete when I bought a new rudder casting from him. Then I rigged the lock down line with some good white rope. Not necessary but but easy to tell at a glance which one you need to pull.
edited by: Quarath, Jul 13, 2009 - 12:35 AM
Posted : July 12, 2009 8:34 pm
Went to West marine today and picked up some 1/4"
line. All their line is 25% off by the way. The
1/4" is way to large for the rudders. What is left
from the old stuff is smaller than 1/4 but larger than
the 3/16 I also bought. I think that it must be swelled
3/16.
Posted : July 13, 2009 2:59 pm
Forum Information
- 3,206 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
