Prindle 16 Trap on ...
Prindle 16 Trap on Nacra 5.2?
Scott Fickerson
(@prelives)
[#1668]
Hi All - I think I'm about to buy a new Nacra 5.2 tomorrow. Going to drive out and look at it and if it's what I'm expecting, I'll drive away with a new boat. The Nacra has a single trap set-up as it's all original stock parts - I'm buying from original owner. It's a 1981. I have a 1972 Prindle 16 with a new double trap set-up bought through Murray's last summer. Will I be able to move the double trap set-up from the Prindle to the Nacra? (i hope so!)
Thanks!
Posted : October 9, 2010 6:38 pm
Robert Braid
(@turbohobo)
Just measure the length of the Nacra trap wires and if the P16 trap wires are close, go for it.
Posted : October 9, 2010 6:50 pm
Terry McClure
(@golfdad75)
The great thing about trap wires is that if they are too short just add line
Posted : October 10, 2010 6:26 pm
(@erice)
the oem single trap wires on the 5.2 were swaged in with the sidestays
they were for crew so are slightly shorter than ideal for the helm
as said line will make up any difference
check the type of trapeze handle on the 5.2, if it the triangular type with 2 sides of stainless and the bottom the black plastic grip thing twice about keeping them...
on that style you end up being suspended from a plastic lug under the plastic handle...after 30 years the plastic is likely too weak to depend on
1 of mine failed while i was on trap and dropped me in the water. fortunately i reflexly clutched on tighter to the sheet and rudder so the boat didn't sail away and the wind wasn't strong enough to flip the boat
but i did end up twisting and crimping the end of the telescopic tiller extension. was able to shorten it and get it to work again but it's a tad shorter than ideal
this winter i'm planing on switching both sides to the more normal black plastic T style
Posted : October 10, 2010 11:30 pm
Terry McClure
(@golfdad75)
Thanks eerice i looked at mine and that is what is going to happen. Add to my winter jobs.
Posted : October 11, 2010 4:02 am
Scott Fickerson
(@prelives)
Thanks for the responses! I've now added a Nacra 5.2 to my flotilla. I'm going to be sad to sell the Prindle (don't have space or the $ to store both), but am looking forward to learning the ropes on my new boat. Will be trying to switch out the trap set-up hopefully during the week but for sure this weekend. I'll let you know how it works out!
Posted : October 11, 2010 7:38 pm
(@erice)
as the grandfather to the f18, the 5.2 is a great stepping stone to newer boats
Posted : October 12, 2010 1:46 am
