Prindle 18 Hull Material
Finally getting this ol’ boat the tic it’s been waiting for. Daughter and I are going to “social distance” and learn some fiberglass at the same time...
This project will take care of hull delamination and a transom repair.
I used the drill-n-fill method on a Hobie 16 in the past, but would like to replace some core material this time to remedy curiosity and learn something from my mistakes....
This boat has a foam core. Anyone know what was used for manufacture and recommend a replacement material. Looks like it might be a half-inch urethane foam sheet, but my expertise is starting from zero!
Thanks for any recommendations!
Knt
http://www.uscomposites.com/foam.html
These guys are good. Not a source for sheet foam apparently.
https://www.3accorematerials.com/en/products/airex-foam/airex-c70-pvc-foam
I have used this foam before, good stuff.
http://www.mertons.com/Floatation/scored_foam.html
No experience with this product.
search airex foam
Edited by gahamby on Mar 29, 2020 - 03:24 PM.
If in doubt or unsure, you can go with a higher grade/strength. All of my F25C core replacement done with Corecell. Try or keep an eye on Noah's Corecell discount bin: http://www.noahsmarine.com/corecell/
James
F25C+
H17+
Thanks for the info! I’m sure it would be fine to leave out some foam, or even re-attach to the old foam. Just thinking I’ll cut and replace some for education and curiosity. The foam piece I cut out is between 1/4 and 1/2 inch thickness. My plan is to buy 1/4 inch and build up, however does the foam shrink with age and deterioration? Undecided if I should buy quarter or half-inch foam and which type foam to try....
Thanks for your inputs!
Knt
- 1,708 Online
