Prindle 18' Shock Cord Replacement on Trapeze
Hi! I'm relatively new to sailing catamarans and I'm replacing the shock cord & lines on my trapeze. I was just wondering how tight should the shock cord be? (I wasn't able to get a sense based on what was on there already because it was pretty stretched out)
Posted : February 15, 2021 4:40 pm
Tight enough is when there isn't a slack in the lines that lets the hooks slap you. A fresh shock cord is something your should replace fairly often. After taking up the slack a couple times, it's time for replacement. Tighter is better, and shock cord just loses it's ability to retract after a year or two.
Posted : February 15, 2021 4:59 pm
Forum Information
- 2,835 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
