Prindle 18 traveler replacement
The traveler car is easy to replace, just drill out the rivets in the end cap and remove the end cap. The car will come right off. When you replace the end cap you can either rivet or use some SS screws. If you plan on keeping the boat for awhile buy the best replacement car Murray's has to offer.
Posted : September 30, 2008 7:45 am
Not positive on the type but my guess is aluminum since its not structural (you will know for sure if they drill out easy). If aluminums the case a simple hand rivet tool will do the trick, about 20 bucks in a good hardware store. For the SS rivets I bought a pneumatic tool.
Posted : October 2, 2008 11:47 am
Forum Information
- 5,964 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
