Prindle chainplate ...
Prindle chainplate question
(@zirie1982)
[#8120]
Has anyone ever replaced chain plates on there cat?
“Prindle 18-2” in particular. I am recoreing the decks and Planning on installing new chain plates while I have it opened up.
Any words of advice, would be much appreciated.
Posted : April 2, 2022 3:35 pm
(@raisehull)
are they really worn out?
Posted : April 3, 2022 1:55 am
(@revintage)
If it ain't broke, don't fix it!
Posted : April 3, 2022 5:48 am
(@zirie1982)
Thanks for your input fellas !
I will do a good visual inspection when I open up the deck, and if all looks good I will close the deck back up with ultra light core cell foam and fiberglass.
Posted : April 4, 2022 1:20 am
I went through the trouble to remove both bow decks when 1 bow tang failed
also broke through a (second) bulkhead to replace both side-tangs when 1 chainplate/tang failed
it may not be a bad idea to replace when you have access as preventative maintenance - esp if the cat was used in salt water
Edited by MN3 on Apr 05, 2022 - 08:01 PM.
Posted : April 5, 2022 2:00 pm
(@cholley12)
On a boat this old? It would probably be smart preventive maintenance. You will have to get some fabbed up though
Posted : April 11, 2022 5:17 am
(@zirie1982)
Thanks guys! I’m gonna install new ones for the long haul!
Posted : April 11, 2022 6:28 am
