Prindle jib question
Technical Help
4
Posts
4
Users
0
Reactions
2,491
Views
Take the jib sheets forward and shackle them to the point where the bridal wires and the forestay meet and sheet them in from both sides, this will tighten everthing and bring the mast forward as well. Use this method if your wire portion of your jib halyard happens to break while sailing. It will stop the extreme movement of the mast while sailing and allow you to get back safely.
Posted : June 8, 2011 11:31 pm
I would never recommend sailing without the jib as you would find it hard to tack, then have to jibe probably resulting in capsize in heavy wind. Better to reef the main, but you'll have to put reef points in and a new nicopress on the halyard. Just sail the boat as normal & let off the traveller as you feel overpowered. Pete
Posted : June 9, 2011 2:03 am
Forum Information
- 2,456 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
