Prindle rudder ques...
Prindle rudder question
(@msedc1997)
[#2189]
Is the rudder uphaul supposed to be a pulley and spacer or just a spacer? One of mine has a pulley and spacer and the other just has a spacer. Murrays diagram just shows a spacer. Any help? 😕
Posted : July 10, 2011 9:31 am
Peter knapp
(@pknapp66)
The original one used the pulley. Later they did away with the pulley and just put in the spacer. I believe
the other pulleys in the casting are the same and you can use one of them if you want.
Posted : July 10, 2011 10:54 am
(@kasper)
check this post: http://www.thebeachcats.com/pictures/?g2_itemId=72614
The photos helped me get mine rigged properly. The rudders are impossible to pull up if you don't use the pulleys properly.
Posted : July 10, 2011 9:02 pm
(@coastrat)
i used all pulleys on mine, they work great! put a ss washer between them.
Edited by coastrat on Jul 11, 2011 - 07:20 AM.
Posted : July 11, 2011 1:18 am
