quick question..sis...
quick question..sister clips prindle jib halyard
 jdb
(@jdb)
[#5101]
I am new to using sister clips and ready to replace the halyard. What do you recommend I use to fasten the clips to the line? Seizing wire? Thanks in advance for your suggestions.
Posted : July 8, 2015 6:33 pm
I'm not 100% sure of what you mean....but, I use sister clips each spring, to hoist the jib, then remove the extra line til fall.
My clips each have a small hole. I put the line through the hole, & tie a single small stopper knot. that's it. Mine look like this;
Posted : July 8, 2015 9:14 pm
(@hullflyer)
Hog rings work best
Posted : July 9, 2015 3:06 am
(@wolfman)
Hog rings and then cover with electrical shrink tubing so they don't tear your jib.
Posted : July 9, 2015 5:36 am
(@nacra55)
You all like to spend money. Sister clips, hog rings, shrink tubing.......
Tie a sheet bend.
https://en.wikipedia.org/wiki/Sheet_bend
Posted : July 9, 2015 8:42 am
(@hullflyer)
The smaller the attachment the easier it is to go through the jib luff when it is zippered
Hog rings were used when they were new from the factory
Posted : July 10, 2015 3:36 am
