Referbing Older Hob...
Referbing Older Hobie Cat 18--Rope or Bungee for tramp?
(@goodsailing)
[#4892]
Looks like bungee would be easier to install, but wouldn't rope allow tighter fit especially if non-sagging (when wet) rope were used? Rope is there now, but it's got green algae all over it and needs replaced.
Posted : February 9, 2015 1:20 pm
(@dogboy)
Don't use bungee.
Use solid line (1/4" pre-stretch). Tighten the tramp incrementally until it is drum tight. Don't try to do it all at once or you may pull out a grommet. For the cleanest results, start with the aft lacing first and then do the center lacing.
Posted : February 9, 2015 9:49 pm
Don't use bungee.
Posted : February 10, 2015 1:15 am
(@presto13031)
Install it on a warm day too, so the tramp will be more pliable.
Posted : February 10, 2015 2:50 am
