Removing old rubber...
Removing old rubber from side rails
(@drmanhattan)
[#3656]
Im removing the nasty ol rubber from the H16 side rails with a chisel and goo gone.
Any better ways out there?
Thanks!
Posted : April 12, 2013 2:04 pm
(@the-renovator)
I would suggest not using a chisel, it will gouge the gelcoat, get one of those plastic ice-scrapers with a solid edge. Unfortunately there is no short-cut to this type of miserable task, you just have to git-r-dun!!! You can try soaking a small area with acetone, let it sit for a while and then try removing the non-slip rubber. Once the majority of the rubber has been removed you can hit it with the goo-b-gone.
R
Posted : April 13, 2013 1:00 am
(@windadict)
the-renovator wrote: I would suggest not using a chisel, it will gouge the gelcoat...
I think this is aluminum trampoline frame not the hulls.
I would try scraper with sharp razor blade to cut as much rubber as possible. Then wire weel and goo gone to remove what is left.
Posted : April 13, 2013 4:37 pm
(@the-renovator)
Good catch there Adam, I forgot that on the H16 the grip-strip is placed on the aluminum rails....... :doh:
Edited by the-renovator on Apr 14, 2013 - 08:09 AM.
Posted : April 14, 2013 2:08 am
