Soft spot repair
I have a solcat 18 and i recently found when i was righting the boat after capsizing that on the inside of the port hull there is a major soft spot (from the rear beam to the front beam). any tips on how i should go about fixing it would be great!
I have found the same on both of my Solcat 18's. Im thinking about separating the deck from the hull and re-glass the entire deck from the inside. The week decking on mine is from the stern to about the middle in addition to several areas on the hulls,,,, de lamination 6-8" to 10-14". seams like the best idea
Some of the guys here have hulls that have more area injected than not! An hour searching will get you all the info you need.
Here is an idea for doing large areas quickly, bottom of thread.
http://www.thebeachcats.com/forums/viewtopic/topic/13937/start/0#pid41365
Edited by Edchris177 on Oct 20, 2012 - 12:22 PM.
- 4,223 Online
