Soft Spot Urgency
I found that while sailing my P16 last weekend, my crew sat down and I heard the notorious crack associated with a soft spot. My question is simple.
What is the urgency of a soft spot and can it wait for winter? What are the cons of putting it off?
Some considerations for the repair might include drilling many holes through the outer skin and foam (and not through inner skin); letting the inside really dry out well (lots of holes and sun); using West System epoxy and syringes (well worth the money). With the West System, I would use slow hardener and do the work in the morning, so the epoxy fills all voids before setting up. Mix small amounts in the container as large ones flash quickly, even with slow harder.
Edited by traphappy on Jun 10, 2019 - 11:37 PM.
- 1,729 Online
