spinnaker retrtieva...
spinnaker retrtieval lines
(@wayler1)
[#2094]
just setting up snuffer spinnaker for 18HT, what method of line set up allows proper retrieval of entire chute, using midpole, nice factory 'mouth', or toilet bowl as I believe some refer to it, 3 patch spin, initial method of simply running one line through lower 2 loops to top patch does not place entire chute in bag
Posted : June 19, 2011 3:53 am
(@nacra55)
Top patch needs to be higher and hoop needs to be further toward the front.
Posted : June 19, 2011 7:19 am
(@hullflyer)
If you are using a seperate tack line, make sure it is released completely or it will not allow the spin to go all the way in.
Posted : June 20, 2011 12:02 am
(@wayler1)
have tack line, patches were on the 18HT when purchased it from someone who never used chute, pole set up same as original owner who can not track down
Posted : June 20, 2011 1:39 pm
(@nacra55)
The only other thing I can think of is going all the way to the head with your snuffer line. Never tried it, but have thought about it because I have the same problem with my non-race spin.
Posted : June 20, 2011 2:04 pm
Is your a "stock" spin for that boat?
have you tried using just the top 2?
i wouldn't go remounting your ring until you have tried all other options but if its not all stock gear it may need to be adjusted..
my tornado spin can be a pain to get to snuff perfectly
Posted : June 20, 2011 2:35 pm
(@wayler1)
yes the chute for the 18HT was factory Italian with boat originally,
Posted : June 20, 2011 3:00 pm
if you can't figure it out, you may want to ask on catsailor.com as many of those guys have had an 18HT
Posted : June 21, 2011 1:37 am
(@pm)
If you have your snuffing line tied directly to your top patch, then it is simple mechanics:
1) move the spin back in the sock (longer sock, or extend the retaining strap at the rear)
2) move the hoop forward
Posted : June 21, 2011 1:44 am
