Standing rig life, Old topic, different take
Seems like everyone I talk to has never replaced them on the old school boats. I've done them on my boats for the peace of mind though. If the lower fittings are getting splashed with salt water you'd assume they would be the same as the shrouds.
When I got my Nacra the previous owner since 1984 said the rigging was original including stays etc. The thimbles were starting to bend but as far as corrosion it was still ok. Was a Houston Texas boat so saw both fresh and salt water.
I suspect the rigging was 316 stainless not 304 like is commonly used on all the replacement stuff I see online now and that's why it lasted so long. I went ahead and got a big spool of 316 cable when I replaced all of it. It rates at about 85% the strength of 304 but upping the size from 1/8" to 5/32" fixed that. Probably not necessary considering a lot of manufacturers probably used 316 cable stock anyway.
I'd guess that's why you hear some people saying OEM rigging lasts longer. Just a different grade of stainless
I feel like the loads on diamond wires are more static in nature and therefore less prone to fatigue than shrouds and forestay. So I would say the diamond wires have a significantly longer service life, for a trailered boat, I always deduct some service life for a beach stored boat. I also don't think I would lose my rig on an 18 foot boat due to diamond wire failure so it's not as much of a concern for me as shrouds and forestay. If I had a larger rig I'd be more concerned.
Edited by jalex on Aug 12, 2017 - 10:31 PM.
I'm not sure what the right answer is here. But if a diamond wire fails, your mast will likely fail quickly thereafter under the kinds of loads that made these old wires fail. The economy of pushing the limit on diamond wires would be quickly eclipsed by the failure of the mast and the cost of mast replacement. Just add them to your rigging order and don't think about it anymore. All of these old wires can likely last well beyond where we all push them to. The problem is that when they fail it is a really, really big problem, that didn't need to happen. It is ok to let someone make some money off us once in awhile.
Well you guys have presented the exact two sides of the situation I have already considered! Yeah, I'm really not too worried about a failure. I'm not sailing in heavy stuff very often. BUT....as dmg says, the cost of a failure is a lot higher than the cost of replacement. I guess I'll change the diamonds out too as priorities permit.
I know not everyone is super handy but you can get a swager for like 60-70 bucks. The thimbles are usually reusable if they were decent quality to begin with and the copper sleeves factor out to something like 90 cents where I get them. Get a whole spool of cable and you are good to go to make any length of rigging you need for a long time.
I changed out the upper turnbuckle fitting for a yoke and used a cut down chain plate at the upper tang to allow the diamonds to be made with thimbles. I think the marginal cost of the actual diamonds was like 16 bucks or something each.
diamond wires go through the same metal fatigue due to repetitive loading and unloading, just like side stays
the diamond wires are exposed the same amount to the elements -
you absolutely should replace your diamond wires
I personally would never re-use thimbles - they are prone to crack and failure during normal (single) use
Edited by MN3 on Aug 13, 2017 - 03:43 AM.
As I have posted before, I would advise against using factory made wires for many boats. A lot of manufactures have begun using cheap SS Wire Rope from less than ideal Asian sources. Get them made locally using Mil/Aerospace spec wire made in the USA or EU, and genuine Mil/Aero spec thimbles, forks and etc. It has not cost me any more than factory supplied parts. On more than one occasion actually less. Demand that the thimbles, forks etc. are packed with Lifecaulk or 5200 before swaging so that water will not intrude. I never buy coated wires, you can not inspect what you can not see. No friggin with the riggin
+1
MN3 wrote:
I personally would never re-use thimbles - they are prone to crack and failure during normal (single) useEdited by MN3 on Aug 13, 2017 - 03:43 AM.
Yea you have to be careful. I had a whole package of new ones from salty dog I think that I threw out because they were distorting within the first year of use. But then I salvaged some from a 70s hobie that have the hobie stamp on them and they are twice as thick and don't have a mark on them even after decades. If I have to buy any I try to get the thickest ones I can.
I've never gone to the trouble of packing the sleeves. It would probably extend the life of the rigging a lot but I think I would still end up replacing it every other season just for peace of mind since it's so cheap to do in the garage anyway. I wonder if it affects the holding strength of the crimp to essentially have a lubricant in there. One crimp on 1x19 wire holds something like 80% of the breaking strength of the cable so if you were doubling up on the crimps It wouldn't matter even it it reduced the hold by 25%
tamumpower1 wrote: [quote=MN3]
you may be on to something with older/thicker thimbles - i have not dealt with many of them, i use them mostly for HM splices
re: packing them - it's just to keep water out
Catman uses locktite in there
Edited by MN3 on Aug 13, 2017 - 02:34 PM.
HULLFLYER wrote: As I have posted before, I would advise against using factory made wires for many boats. A lot of manufactures have begun using cheap SS Wire Rope from less than ideal Asian sources. Get them made locally using Mil/Aerospace spec wire made in the USA or EU, and genuine Mil/Aero spec thimbles, forks and etc. It has not cost me any more than factory supplied parts. On more than one occasion actually less. Demand that the thimbles, forks etc. are packed with Lifecaulk or 5200 before swaging so that water will not intrude. I never buy coated wires, you can not inspect what you can not see. No friggin with the riggin
Do you have a good source for this? On the hydraulically swagged rigged, which is what most higher performance boats use, the failure point is corrosion inside the unselaed swagged fitting. I could try to caulk myself on a set of new rigging but I don't think it would do much.
tamumpower1 wrote: I know not everyone is super handy but you can get a swager for like 60-70 bucks. The thimbles are usually reusable if they were decent quality to begin with and the copper sleeves factor out to something like 90 cents where I get them. Get a whole spool of cable and you are good to go to make any length of rigging you need for a long time.
Matt,
I am somewhat handy and looking to make some rigging. Do you have a link of where you get your supplies/swager?
Jonathan Grant
Mesa, AZ
Solcat - gone
Prindle 16 - gone
Prindle 19/spin - gone
Nacra 20 - gone
Prindle 18/2 -
F18 - future list
I have read dozens of threads here stating that coated wire is not as good.(retains moisture, can't inspect, etc).
After purchasing my little Girly boat, (Dart/Spark/Sprint 15, same boat), I did a bunch of reading on the UK Dart site.
A few years ago, production of these boats was repatriated back to the UK, from S. Africa. A consortium of people who have been involved with the boat since forever bought up the rights & all spares & now support/sell under Windsport Catamarans, & are the supplier of class Legal parts.
These boats are sailed in salt, under common reports of winds up to & gusts over 40mph, & use coated wire.
Brian Phipps, one of the principles has stated several times that the SS wire uses oil to lubricate the strands during manufacture, & prevent corrosion later. They use PVC coating to keep the oil from staining sails, & to retain the oil.
https://www.windsport.co.uk/modules/item_detail.php?parent_id=339&img_id=1055
I don't have any test data, but these guys have been around a long long time, I have to believe they know what they are doing.
Strip the coating. That nonsense is just that-nonsense. I stripped the coating on some less than 1 year old standing rigging last week, on a boat that is regularly rinsed and sailed in brackish water, not ocean water, and there were rust stains already present on the wires. A friend lost his rig 2 years ago because the wire rusted through underneath the coating and the shroud failed in the middle. My 1.5 year old standing rigging is rust free on the wires, that isn't to say they aren't rusting inside the fittings but at least they won't fail elsewhere.
Use chafe protection on your sails instead, i.e dacron insignia tape.
I am not a metallurgist, but I do know that seeing discolored SS is not necessarily from corrosion, it is more often than not from contamination of various oxides that have no impact on strength. Being discolored is just that, discolored. On the kinds of SS we use it will take many years for it to corrode to the point that it will fail from corrosion. That a SS wire failed more often than not will be from overload, fatigue or other manufacturing defect. I was just wandering around several of the SS wire rope manufacturer's sites for vinyl covered SS wire and all of them stated something similar to the following:
"A vinyl coating adds an extra layer to protect the wire from dirt, grit, moisture and other abrasions. The coating also helps to seal in lubrication, reducing wear on pulleys and sheaves. A vinyl coated cable is also easier to handle." (from USCARGO Control)
Hard to imagine that they are wrong, since it is their business and their expertise. So in my mind it is about preference and appearance, rather than performance. If you are failing your wires you may want to consider the other failure modes more carefully, because corrosion of SS is much slower than fatigue and instantly topped by overload. I think most wire failures that were actually examined by experts in this area would tell you that poor swagging was the culprit in the failure. The dies that are used to make these fittings wear with use and if the operator is not inspecting their dies and their press carefully and frequently the super close tolerances that are required for a good swage will not be met and the designed breaking strengths will be greatly reduced.
but are these specifically talking about sailing in salt water?
A few sailing clubs are inland ponds. Most are oceanside, one has 44 Dart/Sprint 15's.
They did a survey on rigging failures, over 80% were on forestay, specifically the short bit of wire between the hound & swivel. The rest were at fittings, none were mid cable.
Reading the racing reports, they often sail in 30mph, with gusts into the low 40's, when all other Cats stay on the beach.
Some hardcore racers change out every 3-4 years, but there are dozens of boats with decades old rigging. Years ago, they used 3mm wire. Since changing to 4mm wire failures are almost non existent.
Being an undecanvassed boat, they probably do not see the stresses that the higher performance Cats experience.
I don't think the cover prevents water ingress, it is very difficult to prevent it from permeating via capillary action.
Again, I am not a metallurgist, but I did work for a company that manufactured SS rigging parts and SS that was used in papermaking plants and a lot of other steel products. SS does corrode, but it does so extremely slowly from what I understand, even in environments far harsher than warm salt water (like various papermaking processes). I really doubt that the presence of the vinyl covering has any impact one way or the other in terms of the rate of corrosion. Other failure modes are far more likely in my humble opinion. Just look at all the monohulls out there with SS rigging, they are not replacing their rigs every two years. And their rigs are often under high tension 100% of the time which means they can include another failure factor called hydrogen embrittlement. I don't think any beachcat rig is under the same kinds of constant high tension that those guys use. So the failure modes I think we need to be concerned with in regard to the actual wire are: 1) overload 2) fatigue 3) abrasion 4) bending. As to the SS fittings I think the best we can do is to use competent companies that have the right and well maintained swaging equipment. The competent rigging companies have to regularly submit test samples for load testing to maintain their certifications. Most companies that do any amount of swaging are involved with cable assemblies used in lifting and that is pretty well regulated. Now if you are doing your own swaging, that is going to be a whole other story.
Edited by dmgbear55 on Sep 19, 2017 - 09:44 PM.
Interesting topic and comments.
Anecdotally, most of the mast failures we see in our salty air are connection points, like shroud adjusters, swaged links and tangs/anchor points. Even dolphin strikers, mast balls and the mast itself.
Also, if you have roller furling jibs with turnbuckles, they can unwind themselves unless you take extra measures.
I recently found a forestay pin missing a ring ding, that had walked away on its own.
So while I have all new wire rigging on my 30 year old boat, I wouldn't want to miss the forestay for the trees.
Edited by nohuhu on Sep 19, 2017 - 12:05 PM.
- 1,570 Online
