Telo-Cat for Prindl...
Telo-Cat for Prindle
6 Users
(@johnes)
[#7207]
Has anyone come up with a way to mount one of these with a roller furler set up on a Prindle
Edited by JohnES on Jul 29, 2019 - 12:11 PM.
Posted : July 29, 2019 8:02 am
Peter knapp
(@pknapp66)
What style furler are you using? There is a bracket for the Hobie style furler to mount that telocat. You might be able to mount this style on a ronstan or harken furler drum.
Edited by pknapp66 on Jul 29, 2019 - 03:41 PM.
Posted : July 29, 2019 9:21 am
yes
throw it in the trash and add a 5" piece of cassette tape to your bridal (one on each side)
Rick White used to swear Abba (tape) was the fastest
I actually use vhf tape - it is thicker and lasts longer than audio tape
Posted : July 29, 2019 9:22 am
Andres Chianale
(@Andinista)
I tried only once with the tello cat, it lasted about a week, i didn’t bother replacing it. You will break it sooner or later passing under the bridles. It was nice to have it, especially the wires at each side, to have a pointing angle reference. Someday i’ll figure out something for that purpose. Meanwhile i tie some red stripes stollen from the sewing box. (I don’t know what a cassette or VHS tape is... 🙄 )
Edited by Andinista on Jul 29, 2019 - 05:43 PM.
Posted : July 29, 2019 11:32 am
Andres Chianale
(@Andinista)
Don't know what a VHF tape is, either... 😀
Posted : July 29, 2019 11:42 am
(@nohuhu)
Beta Tape is Better. :boxen:
John - I haven't been able to figure out how to mount a wind vane with the Harken Roller. Or a good way to mount a GoPro, since there's no shroud adjuster anymore.
Maybe if we added a small triangle bridal plate and drilled that for various attachments?
I worry it will throw my jib geometry off, though.
Posted : July 29, 2019 1:00 pm
really guys - tape works just as well as a bridal weather vane
I have about 35 miles of tape if anyone needs any
Posted : July 30, 2019 2:36 am
(@badfish)
Cassette tape. Preference for Mariah Carey tapes. Will go with Too Live Crew in a pinch.
Bonus, you can put it anywhere you want.
Posted : July 30, 2019 5:01 am
Peter knapp
(@pknapp66)
MN3 wrote: yes
I guess I need an education from those more experienced than me (which is probably most on here).
I mostly use a telocat. I have not found a place to mount one on the I20 with an end pole snuffer. I put
some cassette tape on the bridles and shrouds and went out sailing. As we were sailing on a reach I turned up and down maybe 15 degrees or so (estimated of course). I asked my crew if he saw any significant changes
in the tape. We both agreed that there was not much noticeable change. With the telocat the change is quite
apparent when the wind or boat course changes. So what am I missing that makes the tape as good as the telocat or wind vane? I also find it a lot easier to judge my downwind course with the telocat.
Posted : July 30, 2019 5:40 am
If you have a spin pole rigged i would put tape on the spin bridals too - the spin can add lots of wind interference at the (jib) bridal and provide false results
the tape should flow identical to the weather vane (arrow) - showing you exactly where the apparent wind is when moving and where the true wind is when static
the telocat's only "bonus" are those 2 wires (Reference Arms) showing you the 45* mark (or whatever you have them set to)
you just have to "imagine" those are there (if you used them as a tacking guide)
I am not a fan of tape on the shrouds, they are not in your line of sight and take your eyes off course to observe.
Most of the sailors i sail with use nothing - they feel the wind on their face, set course and use their jib tel-tales to see minor wind changes
I prefer some tape on my bridals - as it is in my line of sight at all times
(edit) just noticed the "we were on a reach"
at that angle of attack, you are maxing out your boat speed and apparent wind - i wouldn't exoect anything more than a quick and small change in the tape and would be hard to notice
Edited by MN3 on Jul 30, 2019 - 02:37 PM.
Posted : July 30, 2019 6:21 am
Andinista wrote: [quote=MN3]
Very high Frequency tape
it vibrates much faster than other tapes - so fast humans can't hear it (but my dog can)
Posted : July 30, 2019 6:25 am
(@badfish)
You should be sailing to the kite's power. Its why crew communication is essential.
The rule that was expressed to me when I started on F18 was...
Upwind - Skipper's head is in the boat making sure they keep her moving and crew's head is out of the boat calling tactics.
Downwind - Reverse that. Skippers head is out the boat calling tactics and crew's focus is keep the kite pulling.
Posted : July 30, 2019 7:10 am
(@nohuhu)
I’m surprised no one is using spare tell tales for this.
Posted : July 30, 2019 10:08 am
nohuhu wrote: I’m surprised no one is using spare tell tales for this.
I have in the past -
problem is, no matter if I buy tell tales (non stop nylon), use yarn, or magnetic tape - they are gonna get caught/fouled at some point.
tape doesn't last as long (usually fade or tear) but i have 4,000,000 feet of tape from my youth
tel-tales cost more than a 6pack - why buy when "I have"
Posted : July 30, 2019 10:17 am
maybe i need to revisit this device ...
Posted : August 5, 2019 2:00 pm
(@badfish)
MN3 wrote: maybe i need to revisit this device ...
Nah. They're not looking at it, it's probably only there to gather telemetry for later analysis.
Posted : August 6, 2019 2:30 am
I guess when you are doing 50 knots ... you know where the apparent wind is
Posted : August 6, 2019 3:03 am
(@badfish)
MN3 wrote: [quote=badfish]
Precisely. At 50 knots, its easy. Forward, that's where.
Posted : August 6, 2019 3:39 am
