Time for some new Ports for the Prindle 18
So I noticed some pretty significant cracking of my port lids so its time to replace them. I figured Id get the Murray viking 6 inch that fits the cat bags.
Has or does any one use the cat bags in their ports? If so have you tried both kinds, Long and Fat? And which do you prefer or thing is more useful?
Edited by Quarath on May 16, 2017 - 06:30 PM.
MN3 wrote: the one thing to check for is that you don't want the bag to be so long that it sits on the "floor"
if it sits there , any water that gets in or accumulates from condensation will get all your gear wet / rusty
True, and remind yourself and crew that anything you put in those bags could get wet, so things like phones and potato chips need to go in zip lock or proper small dry bags.
Have a Fat Cat and have used it 5 years ocean racing.
MN3 wrote: If it sits there, any water that gets in or accumulates from condensation will get all your gear wet & rusty
I lost some first aid gear when it got wet last year, so I have purchased this:
Two layers of waterproof. I have an active project to build a bag that will store flares and tools up high, easily reached from the port hole. I need a 6" aluminum ring to hold it in the hatch opening.
http://first-aid-product.…kking-first-aid-kit.html
Nice!
Keeping flairs dry sounds like a pretty valuable idea!
Not sure what is the best way here, and Ymmv - but if i was going on an ocean cruise or anywhere solo out of our local bays, I personally would keep them in a drybox (or bag) on the deck of my cat or somewhere else above "ground" so i can access them in a capsize or total failure
Quarath wrote: So I noticed some pretty significant cracking of my port lids so its time to replace them. I figured Id get the Murray viking 6 inch that fits the cat bags.
Has or does any one use the cat bags in their ports? If so have you tried both kinds, Long and Fat? And which do you prefer or thing is more useful?Edited by Quarath on May 16, 2017 - 06:30 PM.
Used them all the time.. The only issue I had with the Prindle 18 was there banging against the sides of the hulls if I put something heavy in there... kind of like a Chinese Water Torture. Be sure that you leash the lid to the boat.... could ruin you day if the goes over the side
I opted to get an extra pocket sewn onto my tramp.. easier to get to and held more stuff
JohnES wrote: Be sure that you leash the lid to the boat.... could ruin you day if the goes over the side
Two good points. You can hang food, tools or the first aid kit from the lashing of the port lid which wil give you easier access.
When I get another trampoline I will have them put TWO zippered pockets on the new one. I love the one I have now.
Thanks for all the info sorry it took so long to get back. Im leaning to wards the fat bags myself. I was worried about it clunking around if put much in there but not even sure how i want to use them yet. I don't really want to put much emergency stuff there as I want to be able to access stuff regardless of boat orientation or weather. Was very interested in tethering the lids somehow as I am paranoid of loosing them if I have to get in there under sail. Got a sweet new tramp from Ben at Salt City Sailing. It will be nice to get this port issue fixed. hoping I can get the old ones off ok. who has actually removed and replaced before?
Quarath wrote: Was very interested in tethering the lids somehow as I am paranoid of loosing them if I have to get in there under sail. hoping I can get the old ones off ok. who has actually removed and replaced before?
I replaced both mine through Murrays.
https://www.murrays.com/product/01-421/
I used bolts and nylock nuts instead of screws to attach the new lid frames, and under one of the nuts inside the hull I put a nylon loop to tie a tether line to, the other end of the line ties through a hole I drilled through a flange in the underside of the lid. Like this, but smaller:
https://www.fastenal.com/products/details/0774300
I have to say that the white ports I used are not very UV resistant. After three seasons they are as brown as the three-decades-old ones they replaced. If I were to do it again, I will get the black ports. Make sure you get the ones with the lip in the frame if you want to use the Cat Bags with them. Not all lid frames have the lip.
Thanks, I was considering black then decided on white. I might have to reconsider now. Mine are currently installed with SS screws. Was thinking of just reusing them but saw somewhere the nylon bolts were recommended. Still deciding. I like the tethering idea you used but I'm unsure how that works with the bags in as the tether connection would be outside the bag,
i have white one - yup they will all fade in time but buy a good known brand and they will fade slow
one thing to know - not 100% sure if you have curved decks lids or not (most have some curve) and flat ports will require some extra attention
you should build a shim (or re-use what ever is there currently ) - and when you screw the top to the deck - do it without the lid screwed in - and slowly seal it down a little at a time - using the diametrically opposite method (12o'clock, then 6, then 3- then 9, etc) testing often that you haven't distorted the threads - if you don't you may/will find your new lid wont screw in - or worse it will go in an not come out....
I have always used ss scews with nylock nuts - nylocks over lock washers and nuts because you wont be able to seat all the screws and nuts with a lot of force as this will distort your shape
Quarath wrote: saw somewhere the nylon bolts were recommended. Still deciding. I like the tethering idea you used but I'm unsure how that works with the bags in as the tether connection would be outside the bag,
I would not use nylon bolts. What you may gain in ounces of weight is offset by weakness, low UV resistance, and expense. MN3 makes a good point about tightening the bolts.
When I use the Fat Cat bags, I have put a small hole in the side of the bag to run the lashing that ties the lid on. I use small diameter cordage, like batten ties.
MN3 wrote: Nice!
Keeping flairs dry sounds like a pretty valuable idea!Not sure what is the best way here, and Ymmv - but if i was going on an ocean cruise or anywhere solo out of our local bays, I personally would keep them in a drybox (or bag) on the deck of my cat or somewhere else above "ground" so i can access them in a capsize or total failure
For ocean sailing I created a Velcro strap from 3" wide stock that has a sewn loop to hold a flare and a whistle. It wraps to the life vest through your neck and arm holes, so it stays available in front. The VHF radio is attached to the other side of the vest, so if you go into the water you have what you need to signal and get help.
Here's a photo of my son Cutter's vest showing the black elastic band and the flare. The waterproof VHF radio is behind it, out of site. This photo was taken about 5 miles offshore in the Pacific, and that is Platform Gina in the background.
If you are just talking tools and spare parts, I have a carabiner attached to the inside of the port lid, with lines tied to 32 oz Nalgene water bottles. Some bottles have tools and some have parts. I also throw in some rice as a desiccant. The bottles just lay on the bottom of the hulls and can be pulled up by the lines. The lines also keep the deck port lids captive.
This is mainly for multi-day island trips. The thing is, when I go for a day sail, I'm just too superstitious to remove any of it from the boat.
https://www.rei.com/product/106339/rei-co-op-nalgene-wide-mouth-loop-top-water-bottle-32-fl-oz
Edited by mattson on Jun 12, 2017 - 02:37 PM.
Good call on the rice - and if you ever get stuck on a deserted island, you can have a meal too !!!
I use an old "cosco sized" helmans containers for gear and stow it in my front port (i have a large hinged access port) - (prob too big for a 6" port). in this container i have a sewing kit (hopefully for sails, but ya never know who is gonna need an emergency stitch), spare glasses (i usually only have sunglasses on during sailing but if you get caught with no wind, and have to paddle/float home in the dark....), a very small first aid kit (some blood clotting powder, band-aids, neosporin) and some spare parts.
I have another plastic container (old planters peanuts) that i have a multi driver (has both philips and standard), small vice grip pliers, a 7/16th's wrench (fits rudders), assorted cotter pins and a shackle or 2
So ports came in. Bags apparently were not in stock but coming. Not much on the inside to hook a tether to. I guess I can try to drill a hole horizontally in that center bit and tie something. Or epoxy something in the hole or somewhere else on the bottom. or maybe even fine a short screw the right diameter that can go in the hole to hold something. Just Dunno yet.
The SS screws that currently hold my ports in are screws not bolts they have no nylock nuts I can feel the points sticking out inside the hull. Seems to just be tapped into the fiberglass. But they also seem to be doing good job just not sure they will after I remove the old ports and clean everything up.
Which reminds me any tips on removing old sealant for the old ports before I start with the new ones.
I cut a short section of PVC pipe and drilled a hole in the side of it to fit over that small stub in the lid. Then I glued it on with epoxy. I threaded a small line through pipe to hold the carabiner. It was a crap shoot as I didn't expect them to hold as the lids look like polyethelene, but it worked. I may drill a hole through the stub and put a pin through it as a back up.
Quarath wrote: The SS screws that currently hold my ports in are screws not bolts they have no nylock nuts I can feel the points sticking out inside the hull. Seems to just be tapped into the fiberglass. But they also seem to be doing good job just not sure they will after I remove the old ports and clean everything up.
I would consider replacing with bolts and nylocks, but that's just me. Important: Since the lids may not match the hull contour exactly, don't torque them down really tight. You will distort the ring and never get the lid off and on.
Bingo! I replaced the ports on an H18 Magnum with white Viking ports. To secure against loss, use a foot long piece of thin line, I had some 2mm Spiderline. Just lightly hammer the end of the line to flatten it, then push an awl through the line, & "work" it a bit to open up the hole.
then simply turn a small SS screw into that boss on the underside of the lid.
tie the other end of the line to the middle of an 18"dowel, or plastic rod. You turn the rod on end & drop it into the hole. It will sit sideways, & is wider than the hole, so it prevents the lid from loss, though I also glued a circle of blue Styrofoam SM to the inside of the cap so it will float. A screw in that small boss is plenty strong.
One other potential Gotcha. The holes on the new Viking ports were not the same pattern as the old! I ended up flipping the hulls, laying a strip of wetted cloth around the inside perimeter, then drilling new holes.
I'll take a picture tomorrow
Edited by Edchris177 on Jun 13, 2017 - 04:32 AM.
+1
There can be a decent amount of pressure built up in the hulls and i wouldn't trust my cat to a screw secured into thin fiberglass.
My biggest concern would forming a small leak and getting lots of water in during a capsize
Some good info thanks. Prindle 18 should be flat mount. I plan to test fit dry first. I hope I can avoid any glass work in the process as far as filling and redrilling holes. I think I will put a mini grommet in the fat cat bags for a tether to pass through.
I'll take a picture tomorrowEdited by Edchris177 on Jun 13, 2017 - 04:32 AM.
I was really hoping to avoid having to do glass work for this. I hope that I can make this work without to much trouble.
removing old ports
<img src=" https://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=128185&g2_serialNumber=4
" alt="" />
Nice and Clean
New lids with tether and floats
New Tramp and Ports (not sure why it rotated it)
Edited by Quarath on Jun 30, 2017 - 01:20 AM.
FYI, if you're doing this job now or in the future, I highly recommend these Beckson marine ports: http://www.beckson.com/twistdp.html. Unfortunately the twist version is only available in 5" but these are sooo much better and easier to use than the screw out version. They also make them with bags built-in for the cruising crowd.
- 1,649 Online
