Tornado help
9 Users
(@bacho)
[#2523]
How repairable does this damage look?
Posted : October 24, 2011 12:24 am
(@hullflyer)
It appears that a previous owner added a front trampoline and maybe over loaded it, so I would want to look inside to see if there was any more damage before I considered repairing the boat. It looks like a pretty large and expensive project.
Posted : October 24, 2011 12:42 am
(@bacho)
The lower picture is from a tree branch. The upper was a front tramp as you guessed. This is a 1990 model. Worth messing with for $1500 with everything else in good shape?
Posted : October 24, 2011 1:52 am
(@bacho)
Posted : October 24, 2011 1:54 am
(@dichtbijzee)
Doable, but the owner has had a forward tramp on it as well, look out for wear and tear there. The inside hole is on a nasty place with high loads.
Posted : October 24, 2011 2:19 am
(@Anonymous 945)
Fill the holes with West Epoxy mixed with high density filler (404). After sanding, apply 3 layers of 2" or 3" cloth (Jamestown Dist). Sand & fair, then another application of epoxy with 404 to really fair edges. A very easy repair. Pete
Posted : October 24, 2011 2:56 am
(@coastrat)
you can always lowball....and let it sit. winter is near and so is christmas, the casual buyer has the advantage here. if he had the skills to fix it he would have, otherwise he's looking at big bucks from a shop. it's under 150-200$ in materials(west system,404,glass,gelcoat,sandpaper,acetone,tape,etc.), a few afternoons of labor(8-12 hours ), some beers. this also depends on your experience/confidence with glasswork. youtube has a wealth of videos on the topic...it ain't welding!
Posted : October 24, 2011 3:27 am
(@bacho)
Would this boat be a marstrom? What would it be worth in good shape? Its about 6 hours away from me, I am very willing to make the drive if its worth fixing.
I am a far better metal fabricator and just learning glass work. I did a bottom job on my h18 fixing a hole in it so I feel I can fix that hole easy enough but the cracking concerns me more. I wish it was just welding!
Edited by bacho on Oct 24, 2011 - 10:57 AM.
Posted : October 24, 2011 4:53 am
Dustin Finlinson
(@Quarath)
Little bit of Duct tape and your golden 😀
Posted : October 24, 2011 5:05 am
(@Anonymous 945)
How much is it worth ? The tilt trailer alone is worth $1500. Out of 400 cats a Belgian sailor picked up a young rookie kid at his yacht club & finished 4th in Round Texel. Think of epoxy repair as "soft welding". The key is 2" or 3" cloth so no loose edges & minimum fairing. Pete
Posted : October 24, 2011 8:06 am
(@bacho)
No tilt trailer. He has been pulling it at 10ft wide!
Posted : October 24, 2011 8:13 am
(@zachhansman89)
hey bacho if your not going to buy could you pass the info along i need parts bad got good hulls and no parts!
Posted : November 1, 2011 2:46 pm
(@bill40421se)
I have a Tornado main block setup if anyone needs one. 🙂
Posted : November 1, 2011 9:30 pm
(@bacho)
zachhansman89 wrote: hey bacho if your not going to buy could you pass the info along i need parts bad got good hulls and no parts!
I plan to buy it.
Posted : November 1, 2011 10:17 pm
(@beachsailor)
The boat is a Sailcraft. From the closeup pictures it looks like there could be some front tang damage and seperation in the bows. But the price is right.
I have a 91 marstorm in excellent conditon if any one is looking.
Edited by beachsailor on Nov 02, 2011 - 05:41 AM.
Posted : November 1, 2011 11:39 pm
(@Anonymous 945)
And I have a '90 Marstrom available--pics on classifieds tomorrow. And zackhansman89 I have parts you need to put your hulls together. Pete
Edited by pbegle on Nov 02, 2011 - 06:20 PM.
Posted : November 2, 2011 2:38 am
