Turnbuckle with a roller furling
My Prindle 18-2 has a roller furling and it is attached to the forestay with a turnbuckle. I just can't get the negative thoughts out of my head regarding the turnbuckle unthreading one day while the furler is spinning. Am I over thinking this or is a turnbuckle just a bad idea here? Thanks Pete
I believe this is stock for the 18-2 and should not be a problem.
http://www.murrays.com/02-2545-42.html
since you would have to cut off the turnbuckle. you would probably need to replace the entire forestay to change to another system (chainplate or thimbled end) - not a big deal but some Loctite and rigging tape would be cheaper
Edited by MN3 on Apr 20, 2015 - 07:43 AM.
MN3 wrote: I believe this is stock for the 18-2 and should not be a problem.
HaHa there you go then, never would have guessed what he described was the factory setup.
- 3,385 Online
