venture 15 jib sail
(@goldwingnut)
[#3231]
Does any one know what size the jib sail is on a venture 15 straight hull? I have only sailed with the main so far but the furling parts are on the cat. I might as well try using them. Dimensions please not just sq ft, Thanks.
Edited by goldwingnut on Aug 16, 2012 - 10:35 PM.
Posted : August 16, 2012 4:34 pm
(@erice)
no idea on the measurements
but if you have the forestay and the jib blocks you should be able to work it out almost perfectly
Posted : August 17, 2012 12:07 am
(@goldwingnut)
The height on the forestay I get. Completely unfurled to the jib blocks? I never had a jib sail before. There aren"t too many other cats in north western Wisconsin.
Edited by goldwingnut on Aug 17, 2012 - 08:32 AM.
Posted : August 17, 2012 2:32 am
(@jima4425)
Hi. Go to the sailrite site and look up venture 15. They have dimensions for furled jib and non furled jib.
Posted : August 17, 2012 3:50 am
Peter knapp
(@pknapp66)
Super sail makers has a new jib for $315.
Posted : August 17, 2012 9:08 am
