Any F14 Builders Plans?
Darryl,
It is not that foils don't work. The problem is that the Trifoiler and the Windrider Rave sail very poorly when there is not enough wind to foil. I would be nice to have a little, high-performance tri that would sail well ON the water as well as above it. <img src=
/> And maybe sold either with or without hydrofoils.
I understand fully what you are saying Mary, and I agree 100%, that is why I am using the Alpha Omega F14 as the centre hull and building two smaller versions of that hull for the ama's. This is so that it will have an exceptional performance in light, non-foiling conditions. Even when it is foiling I am intending for the actual hulls to be able to come into contact with the water as an assist in heavy conditions without detriment to it’s stability or speed and thereby increase it’s all round sail ability, it’s stability and it’s sea worthiness. You could say that it will be a foil assisted tri but I am looking at the project as a hybrid tri and foiler that hopefully takes the best from both and functions through the widest range of sailing conditions better. That’s the goal any way. Ohh, and it has to look
pretty
too, (if it didn't no one would want one)
We went through this in earlier posts Doug, and the problem is two fold. Back then the exchange rate between the Australian and the American dollars made a direct import to the states a rather expensive exercise, and that exchange rate has only gotten worse since then, and secondly, we looked for a builder in the states to make the Alpha Omega F14 there, but, although there was interest none of the manufacturers we contacted could see enough profit and/or demand there to enter into the venture. Pity as we would love to see the Alpha Omega F14 sailing in the US of A.
When will the Alpha Omega F14 be available in the US. I was very impressed with the video. That little boat screams!!!
Doug
You guys can have the moulds for the 430/F14 for the cost of the freight if anyone is interested.
http:/
Bern
No, not Darryls AO, it's my own design and build.
Bern
No mate, actually I'm more than happy with the boat. What I meant was, my declaration that I actually designed and built the boat seems to kill any further interest in it, particularly here in Oz regardless of it's good form both on and off the water.
Thanks all the same for your generous support but my dreams of providing a very good, reasonably high tech boat to encourage our younger sailors and bring the 14ft cat into the 21st century died a long time ago sadly.
I'd have to do the costings over again, it's been about six years since I had current numbers. Suffice to say way more expensive than a Mari, or Hobie cat, like you could own five or six of either of them for the same $$$ a 430 would cost.
In the mono hull ranks cashed up dads buy these sorts of toys for their sons/daughters but cat sailing dads race their own boats and the kids crew for dad = no market <img src=
Darryl
Would you under any circumstances consider making available a lines drawing/offset table of the A&O F-14?...Some time ago you told me that the design didn't lend itself to timber construction...not a problem...not interested in a wood hulls any way, and as you know there are many ways to make a male plug/mold to
one off
a couple of hulls regardless of how complex the compound curves are.
One of my favorite methods is to hot wire 1 lb density Styrofoam. Easily obtained, easy to work, relatively inexpensive and a quick process if you know what you are doing. Shape of the object (hull) is only limited by ones skill and imagination.
Robert
- 3,901 Online
