How do I add dolphin striker to H14?
2 Users
Rusty West
(@Rusty)
[#15465]
I have purchased the support post and dolphin striker. I understand I need a "threaded" mast base. Do I have to drill a hole though the cross bar to get the support post into the mast base? How would I line it up? My goal is to add a trapeze. Are the steps listed anywhere? I tried to google them but no luck. All suggestions are appreciated.
Rusty
H 14
Nacra 5.8
Posted : May 16, 2005 10:43 pm
(@_removed-account)
Four Star Admiral Registered
Rusty,
You're in for a lot of work if you try it that way. Hobie and Murrays sells an add-on dolphin striker that is really simple to add on. 4 rivets and you're done.
I have converted a 14 to turbo and used the factory dolphin striker, which is solid like a Hobie 16. In fact, the rod is the same as a 16. I had to drill a hole in the 14 mast step and thread it. I then figured about where I wanted it and drilled a big hole for the rod to go through. I made it a little bigger than the rod so I could move it around. I made the bottom hole the same size as the rod to make it stable. I had the metal wire from a 16, so I straightened it, then rebent it to fit the 14 frame and chased the ends to make threads for the bolts. This process took all day. The add-on one may not be as cool as the solid one, but it is WAY easier to install.
Posted : May 18, 2005 3:32 pm
