Dyneema jib halyard
7 Users
12.8 K Views
Dazz
 Dazz
(@hood)
[#23398]
Hi everyone
Im about to replace the jib halyard on the capricorn, I would like to use dyneema but i am concerned about the stretch as my halyard is not adjustable on water.
are there many peeps using dyneema over wire now?
Posted : August 14, 2008 11:57 pm
(@mikekrantz)
Use vectran if you are concerned about creep.
Posted : August 18, 2008 9:15 am
TEAMVMG
(@TEAMVMG)
Don't do it unless you can rig an easy on the water tensioner
Posted : August 23, 2008 1:41 pm
(@davefarmer)
I'm happy using Vectran.
dave
Posted : August 23, 2008 11:13 pm
(@_removed-account)
Four Star Admiral Registered
Dazz,
the last owner of your boat was a know nothing layabout. Whatever you do change all his systems and rope selections etc.
Posted : August 24, 2008 7:32 pm
Dazz
 Dazz
(@hood)
Thanks Scarecrow, I'm sure TA will be pleased to hear that 😛
There are some realy good setups on this boat that I havnt seen anywhere else.
I have made some changes, done a bucket load of maintenace (all standing rigging, diamonds, all shock cord, new sheets..) mostly so the boat is easier to deal with on a week to week basis.
The forestay is being replaced today, the furler is coming out as the jib doesnt furl anyway. The choice between a rope or wire jib halyard determins the type of pulley that will be swaged onto the forestay.
Im sticking with wire.
Posted : August 27, 2008 2:37 am
 Juha
(@JuhaH)
Hi there,
I would like to replace the jib halyard on my Nacra Infusion mk II. What line are recommending for the halyard? Should I use Dacron or some other material, such as Vectran?
Here's the Nacra's manual how to replace the halyard -> http://goo.gl/ohNDxi .
Thanks in advance.
Posted : June 23, 2015 2:55 am
Dazz
 Dazz
(@hood)
What a fortune teller you turned out to be Scarecrow. by the time I had finished it was virtually identical in setup to the C2, so when i made the move to a new boat, everything was the just the same but faster/easier to sail.
Juha, any old piece of string will do for a nacra halyard. If you have the stock hook/ring arrangement then there is no load on the halyard at all.
Posted : June 24, 2015 7:06 pm
Gilo
 Gilo
(@Gilo)
Vectran has a very bad UV resistance. I don't think the line will last longer than 3 years. My preference would be dyneema.
Setting up an adjustable jib halyard is quite easy and definately worth the investment if you are racing.
Posted : June 28, 2015 3:11 pm
