Comments on Capricorn
6 Users
18.9 K Views
Baltic
(@6202)
[#23368]
After some years sailing a Taipan F18, I think I'm ready for a contemporary boat. My current favourite is the Capricorn, first because is the successor of my boat (and I'm pretty satisfied with the Taipan) - and it is the greatest looking F18 around. <img src=
I'd like to particpate on your personal experience with this boat, handling tricks which might be unusal, what to look for if I buy a used boat, etc. - in short: all comments are appreciated!
Kai
Posted : August 9, 2008 5:45 am
(@Anonymous 13274)
Hello Kai -
Solid boat, well thought out, excellent build quality. I've owned one for two years, and have sailed extensively on Tigers, Nacra F18s and Infusions. I am quite happy that F18 designs all seem to have a slightly different
feel
to them, but still compete at very comparable levels across all conditions. If F18 is where you want to be, the Capricorn is a terrific boat and you won't regret the purchase.
Posted : August 9, 2008 9:07 am
Baltic
(@6202)
Thanks, John, for your reply. When you sailed all the main players in this business (Tiger, Infusion, Capricorn) - can you distinguish their strengths and weaknesses? Just your brief, personal opinion ...
Posted : August 10, 2008 10:23 am
(@Anonymous 39462)
I got my Capricorn about 2 yrs ago after having owned a Nacra F18 for the previous two years. Compared to that boat the Cap is, as you would expect, a step forward. It is incredibly smooth to drive, especially upwind. I have found it difficult downwind in heavy airs with a tendency to nosedive. I think this was in part due to a 'bigger head' main that was perhaps to full and was giving too much power and part to me losing confidence. I now have a Landenberger main on the boat and it seems much more controlled offwind. The only build issue I would question is the daggerboards slots which leak at the bottom at the slightest hint of grounding the boards - easy enough to fix (and to avoid!)
For me the Tiger is a bit overlooked now on the basis it is not new rather than its' abilities and is a very good heavy airs boat. The Infusion I would say is a boat that is very easy to go fast on from day one and works well across all wind strengths, with the Capricorn you have to work it at bit more to get the best out of it.
Interestingly enough I believe a Cirrus just won the UK nationals - did someone say the sailor counts for something....
Posted : August 10, 2008 11:31 am
(@Anonymous 13274)
That is what I like most about the class - the sailor makes the difference, but you can keep your brand loyalty, buy sails to suit, etc.
GBR6 - I wonder if you had the same Goodall main that I did, with slightly (40mm) more at the top. With the new 1m limit on the head of the sail coming into effect in January, I expect your new Landy main measures to the new rule and may account for the difference in feel. Here in the US, we get a bit less wind than you do in the EU, and therefore I will miss that extra bit up top in the typical conditions we see. I found that, even as the breeze built into the upper teens and lower 20s, the top of that sail was easy to spill off, which kept me more on my feet once I learned that trick.
Posted : August 10, 2008 1:12 pm
(@Anonymous 39462)
I'll drag it out from the cellar where it lies after being shredded in yet another pitchpole and measure it some time. It had a larger head than the standard Goodall most Caps came with. Upwind it was fine but downwind I struggled and the more I swam the more conservative I became and I think this compounded my problems. I stress the word 'MY' because the other Caps in the UK seemed to not have my problems and, given that I could sail the Nacra happily enough I came to the conclusion it was probably the sail.
Posted : August 10, 2008 4:26 pm
Baltic
(@6202)
GBR6 - do I understand you right that I should make sure that a Goodall main comes with the boat I obtain? I guess this an issue when I come across a used boat. My local dealer offers one from 2006 ...
Posted : August 11, 2008 4:32 am
(@Anonymous 39462)
Hi Baltic - my comment was purely that I found the oversized main a bit of a handle in a blow downwind. I was the only Cap in the UK that I saw with this sail; the others either had standard Goodall or Landy's and they didn't apprear to struggle as much as I did downwind. They were better sailors though....
The Goodall sails to my mind lacked the longevity of Landy's. They felt 'thinner' if that makes sense but certainly seemed fast.
Posted : August 11, 2008 8:56 am
(@stank)
One Star Admiral Registered
dumb question, the original Nacra Inter 18 - is NOT F-18 compliant?
Could an Inter 18 still go boat for boat with the F18 fleet as long as it's not some top level event that requires measuring in?
Just wondering, since there are a few Inter 18s here with the carbon masts, and it would seem to be a lot of $$ to switch to aluminum mast just to be an
official
F18.
Any other differences between the Inter 18 and the F18 box rule?
Posted : August 11, 2008 11:06 am
(@david.ingram)
The North American version of the Inter 18 is not F-18 compliant. But it could easily be made compliant. Yes it would need an alloy stick and alloy bowsprit. With the cost of carbon masts these days your could probably work yourself a very nice deal if you wanted to make the conversion.
By the book, if you don't measure in and you don't comply with the class rules then your not an F18. But, in the real world at local events typically the fleet makes the call on the beach and it's pretty relaxed. At events like MidWinters and regional championships then it's going to tighten up especially if they are going to all the trouble of weighing boats.
Basically the carbon mast and carbon snuffer pole are the only things that keep the I18 from being F18 complaint. For a while the carbon sticks were allowed to race F18 but the grace period has run out.
You have your eye on I18 at a sweet price Bug? Mike was making noise about getting one two weeks ago.
Besides I've always wondered what the I18 could do with a super wing mast. I always felt it never got its proper moment on the water.
Posted : August 11, 2008 6:36 pm
(@Anonymous 6548)
FYI, I ran a Steve Brewin main on my Capricorn that had a bit more depth and size in the head then the Goodall units. I have not found it a problem in the fresh stuff downwind. Make sure you keep the kite open..... do not overshhet and make sure you give it a good ease early when pressure hits. This will help give you a lot of lift on the bows.
[Linked Image]
[Linked Image]
Posted : August 12, 2008 3:17 am
(@stank)
Just saw that Kent's I-18 is still for sail, and given the price yours went for, there may be room to knee-go-she-ate
Either that or Mark H's T boat.
Posted : August 12, 2008 3:49 pm
(@Anonymous 13274)
Either way, you're racing Portsmouth. Grab an F18 and race straight up. You can pick up a Nacra F18 for a song these days and still have only the loose nut on the tiller to blame if you're not hanging with the pack. <img src=
Posted : August 12, 2008 9:05 pm
(@stank)
Quote
I'm listening, but not a very good singer.. <img src=
Posted : August 14, 2008 10:37 am
(@ckuang)
Hey TA, was wondering if you could comment on the differenc ein handling between the Steve Brewin sail and the Goodall sail on your Capricorn? What made you decide to go with the Brewin sail?
Posted : August 14, 2008 11:52 pm
(@Anonymous 6548)
We felt the Goodall sail was a bit to flat in the top for our fat a$$'s. We weighed in at 164kg. Brewin's main whome he was developing under the Goodall badge, had a bit more seam shape and luff curve..... much more depth up high.
Posted : August 15, 2008 12:45 am
(@ckuang)
Sorry for sounding ignorant but is 164 kg heavy for F18? What's the ideal racing weight? Also, with the new sail, did you change your mast setup from the Goodall sail? Sorry for the questions but am interested in a set of Brewin sails for my F16 as they look like a really nice shape
Posted : August 15, 2008 1:48 am
(@Anonymous 6548)
Ideal is 150 to 155.
164 is not that bad if you have a grunty sail and are sailing in a bit of pressure. You do suffer a bit downwind with depth. We were originally 186 when we bought the boat and suffered bad in the light stuff and downwinds.
Did not change the mast settings that much. From memory we ran about 35mm to 45mm on the daimonds and mast rake at the lower gundgeon.
Posted : August 15, 2008 6:02 am
(@david.ingram)
Although I agree 100% with your ideal weight for the boat there are those that feel 160kg - 165kg is ideal. So, it does depend on who you talk to.
Posted : August 15, 2008 7:40 am
 iMax
(@iMax)
hi baltic,
i've changes since last year from nacra's (f18's and infusion) to the ossie rocketship and found out that the capricorn is much stiffer than most cat's. it realy becomes clear in lesser wind (it just accenllerates with every breath). most f18 are not build as good as the capricorn. upwind there should be no faster f18 and down wind i also found out that it is realy improtant not to oversheet your spi. when you keep that in mind nosediving is not an issue. yes, when you put bundy or heemskerk on an prindle 16 they will probable kick your... but when you compare the results of amature sailors it is quite clear that the capricorn is realy a fast cat.
i myself have (unfortunately) decided to offer my 2007 capricorn for sale due to the fact that my two young boys do not offer me the time to go sailing for whole days. therefore i've decided to switch to kitesurfing. but i've your interested in a lightly used capricorn, let me now.
Posted : October 19, 2008 1:54 pm
Baltic
(@6202)
Hello iMax,
thanks for your kind offer - and indeed I'd prefer to buy a slightly used Capricorn instead of a new one. The problem, however, is my old Taipan F18 which is obviously difficult to sell. The german Capricorn distributor is taking my old boat at an acceptable price in. Where are you living?
Posted : October 22, 2008 6:56 am
 iMax
(@iMax)
hi baltic i live in the netherlands (so quite close to you). i'm selling my capricorn including trailer. i could bring it over to you when we can come to an agreement. if you can let me know your email, then i'll send you some information on my boat including some pictures. i'll be travelling to the philippines for two weeks as from coming friday so i might not be able to serpond quickly to your response.
Posted : October 22, 2008 10:35 am
Baltic
(@6202)
... iMax, I just sent you a PM.
Kai
Posted : October 24, 2008 5:40 am
