F16 alternative
15 Users
44.6 K Views
(@Anonymous 6548)
Of course in the F16 Forum the arguement would be a little bias. Care to take it to the open forum or even SA?
Posted : May 26, 2010 7:33 am
(@mikeborden)
Originally Posted by Tornado_ALIVE
Ignorance is beleiving current F16s are built anywhere near to the rule.
Since it seems you know quite a bit about all of the F16's being built right now...
In what aspects(all aspects) are NONE of the F16's being built, NOT to the F16 rules?
BTW, I'm not picking on you, you just happened to make this statement and I was curious as to what you see. <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" /> (Notice the smiley face) <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Mike
Posted : May 26, 2010 7:58 am
(@Anonymous 6548)
Viper could be lighter. Carbon mast to reduce weight aloft, carbon hulls and beams also to reduce weight.
Other F16s could also go down all carbon route, (alloy and glass are second grade substitutes). Bigger carbon beams, reinforced beam mounts both to create a stiffer again platform, more hull volume.
Personally beleive AHPC have nailed the specs and pricing on the Viper as a stand alone class. As an F16, it looks to be the quickest product out there whilst carrying too many KGs for the class. A lighter verson of the same product would off course be quicker..... But likely priced out of the market place.
Posted : May 26, 2010 8:09 am
(@waynemarlow)
You forgot to mention why the Viper is basically over weight, its not the mast nor the hulls which is the real concern. AHPC choose for commercial economy ( cost to the bottom line on the balance sheet )to use the beams rudders and all ancillaries from its bigger sister the F18 and by design choice, to have larger bouyancy ( big hulls )than the other F16's.
If dedicated F16 suitable components had been used then it would be similar in weight to most of the earlier generation designs ie around 115 - 120 kilos.
The Viper is an interesting boat and must be being looked at by many of the lighter F18 crews, it already seems on a par performace wise with the F18's, has a better handicap and best of all, can be beach handled with ease by two crew.
Posted : May 26, 2010 8:35 am
(@mikeborden)
So, it still comes down to weight?
Wasn't the Taipan down to min weight? If that's the case and the Taipan was so good, why didn't everyone build something just like the Taipan? For that matter, use all of the parts off of the Taipan like the beams and stuff, and then just make the Hulls with more volume? Why didn't that happen? Isn't the Taipan still being produced? So the beams should still be readily available, correct? So, other than the cost savings of using the F18 beams and parts, just use most of the parts of the Taipan. I would think AHPC would have thought of that.
Why didn't they do that then?
I'm not bashing the Taipan BTW or AHPC...
Just trying to have a good conversation...
Mike
Posted : May 26, 2010 8:37 am
(@mikeborden)
I have to say that the Viper can be handled by one person on the beach. Yes, if the sand is a little soft, or there is a nice little hill that I have to go up, It's a little hard to push it by myself. But most of the time, I have no problems handling the boat by myself. I weigh about ~170lbs or ~80kgs for you metric folks. <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Mike
Posted : May 26, 2010 8:42 am
(@waynemarlow)
Mike,
I'm not knocking the weight of the Viper at all, just saying that with better design and dedicated parts it could be on a par weight wise with many of the existing F16's.
Either by design or by commercial risk aversion ( using existing parts to limit development costs and thats exactly the right route to go in my opinion ) the Viper has fallen into a real sweet spot for its handicap, good and hope all the new owners will enjoy what is obviously a cool boat.
My guess is that should a new Nacra or Hobie suddenly appear thats 16ft long and down around the 120 kilos then AHPC would immediately issue upgraded components to lower the weight. Nothing wrong in that in my opinion just a MK2 version.
Posted : May 26, 2010 8:53 am
(@mikeborden)
don't worry, I'm just making conversation. <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Trying to see what everyone's thoughts are.
Posted : May 26, 2010 9:04 am
Matt M
(@matt-m)
Originally Posted by Wouter
All the rest is just ignorance.
Wouter
A full carbon, prepreg autoclave full volume stiff F16 will cost significantly more than an A Class and would be superiour to all current F16s in the market.
Seems everybody and anybody in the sailing industry (other than F16 sailors) know this.
Cation, if you want to bring the fight here, you may have more than just F16 sailors posting comments about this.
This comment is not so much ignorance as it seems paranoia.
From a current builder, put a carbon stick on a Falcon and it is min weight. I would figure that makes it at the rule and far under 40K. (Around 20 I have been quoted) I am sure if you brought a 40K check to any builder they would be more than happy to build you something though.
Carbon is not legal in the F18, but it is possible to build a full pregpreg autoclaved F18 which would also be much more expensive and stiffer than the current boats. Why would you not fear this? And how from actual experience can you possibly project that any addition of carbon or expensive production technology will obsolete any boat.
Marstrom builds an all carbon autoclaved boat. They are expensive but has it “taken over” the class – NO. The new Ashby boat (as well as the Flyer II) do not even have carbon hulls, they are Kevlar. Has this made the boats uncompetitive – NO. Is there any huge difference in costs between the brands made with carbon or not – not so you would notice.
A landed Ashby A in the US is right around 30K. You can buy a full carbon – under min weight - Falcon for quite a bit less (~5K)than that, and you have a lot more kit on the F16.
Sorry to get drug into this thread but untruths and exaggerations that espouse doom and gloom or bash each other do not do either of our classes or cat sailing in general any good.
Pete, WTF were you thinking with this post on the F18 site?
Posted : May 26, 2010 10:24 am
pgp
 pgp
(@pgp48)
Well, we had some F18 sailors of note coming over to the F16 forum, giving vent to their views, I figured turn about was fair play.
But, the point has been made. Time to go home.
Posted : May 26, 2010 10:31 am
(@_removed-account)
Four Star Admiral Registered
Thank you, five minutes is up.
http://www.youtube.com/watch?v=teMlv3ripSM
Posted : May 26, 2010 4:39 pm
pgp
 pgp
(@pgp48)
<img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
Posted : May 26, 2010 5:26 pm
TEAMVMG
(@TEAMVMG)
Ok, someone fill me in.........
The viper is how heavy? and the class minimum is what?
(@Anonymous 6548)
No I did not forget to mention beams. If they were carbon also, retaining the same or more stiffness, then that would be an advantage. Extra volume is design choice because it performs better. If you were to build a Blade or Falcon with the same volume, then it would be heavier. Fact is the fat boy Viper is heavier than curent F16s and is competitive if not quicker.
Mike
The Taipan 4.9 is OD for starters, meaning it does not have to compete with market competition within the class. Secondly, the Taipan’s hull volume was too small, the platform not rigid enough to compete in the F16 class and the beam is also narrower then class allows. Increasing the beam length, diameter, reinforcing the beam seats for the extra load and twist for the kite all adds weight. Also remember the Taipan, whilst still a great boat is an old design now (about 22 + years old)
AHPC have just built a boat that sails closer to it’s rating (Viper rating) then other F16s to their rating, thus allowing it to compete against a class that should be quicker.
I would bet they would produce a 125kg boat in line with the Viper, compete head to head with them and develop their own class which would be very similar to the F16, be better marketed, more numerous and active on the race curcit. F18 and F18HT.
Kevlar would be another expensive option. Are the Ashby boats any cheaper then the carbon ones. Why have classes such as the F18 and tornado outlawed the use of Carbon and Kevlar in all but foils, tiller and tiller exentions and fittings. $$$$$$$$. But I am sure they are mistaking.
Brett Goodall has posted a great post summarizing why it costs more for a volume manufacturer. You can do a search or I will find it for you later. Research and development to produce a boat that performs as close as possible to it’s rating, plus supplying a quality product with warranty costs $$$$$.
Posted : May 27, 2010 12:21 am
(@Anonymous 6548)
Myself personnaly, I am currently a Tornado sailor (crewing for a friend) and will be purchasing a new boat soon. Could be an F16 (Viper would ne nice) or may be a taipan 4.9 which will be fitted with a kite for non Tiapan events.
A quote from the F16 forum that sums it up.
Quote
Is absolute stiffness even desirable, or is some flexibility a good thing?
Like weight, I suspect it's importance is overstated.
Posted : May 27, 2010 12:31 am
(@waynemarlow)
AH but the Viper is the first F16 / 104 boat to be regularly put through its paces by Olympic quality sailors. Like all rating systems only the best sailors should achieve the theoretical rated handicap.
On the club scene all the F16 designs are pretty even with no one design ahead of the other whether in one or two handed crew mode, even the oldest designs are still hanging in there with the winner all ways the best nut on the tiller.
Class weight is 107 kilos for 2 handed boats. Most new designs are at that or around that weight using mainly glass construction.
Anyway its been fun to be part of the F18 Forum for 5 minutes, interesting to read on this forum the the wildcat structural problems, I guess all classes whether light or heavy can be beset with problems of one sort or another.
Stiffness in structures can lead to more problems than solve, glider design ( who probably lead the world in composite construction ) have now gone away from very stiff structures, it was leading to structural failure at key points ( stress fractures ) and many pilots felt that they were taking such a physical battering, they couldn't cope physically over longer flights. Food for thought and I would guess the super stiff boats must be nearing this point. I'll start a thread over on the F16 forum to see what we all think of this very interesting subject.
Posted : May 27, 2010 4:09 am
(@Anonymous 39109)
All Aussie Blade,s are built to the minimum weight. They are all Glass/ Kevlar just like the Taipans.
So I don't see the problem. If these guys can do it why cant everyone else.
A few years ago when I had my F18 there were guy's in Europe that put forward a proposal to reduce the minimum weight of the F18 to 140kg.
Unfortunately for the class it was rejected.
Posted : May 27, 2010 5:07 am
(@wouter)
Stephen,
You are so full of BS !
Quote
Last time I checked the Tornado's also have carbon masts.
Wouter
Posted : May 27, 2010 5:09 am
(@wouter)
Note to everyone involved in this discussion.
We are poluting the F18 forum. This is not the place for this thread. So stop feeding the troll.
Wouter
Posted : May 27, 2010 5:12 am
TEAMVMG
(@TEAMVMG)
How about an answer 1st Wouter?
Posted : May 27, 2010 5:35 am
(@Anonymous 6548)
Stephen,
Quote
Wouter
You ar right, I slipped up on that and should have known, but it was a minor slip...... how about addressing the rest of my post before calling BS........ Or is it you that is full of BS.
In 2 up mode, the Viper's weight is 125kg whilst F16 class is 107kg. Note, the Taipan is 102kg without spinnaker gear, much smaller volume hulls and tiny beams.
Posted : May 27, 2010 6:02 am
(@wouter)
All the other stuff is BS as well.
The Aussie Blade and Falcon hull have basically the same overall volume as the Viper. But more importantly they have as good as identical surface area which is the only meaningful measurement when deailing with hull weights. Additionally, I've upgraded a Taipan design to F16 specs myself (from the bottom up) and what you call tiny beams still result in platform stiffness comparable to a Nacra F18/Hobie Tiger. You make it sound like I'm (and the quoted F18 sailors) are sailing a noodle when that is simply not an accurate desciption of reality.
There is more but I'm not going to endless repeat all that stuff, because you have proven to simply ignore everything that is said and restate the same falsehoods over and over again; often only days later.
The end of the discussion is the fact that any US buyer can get himself a class minimum weight Falcon F16 when ordering the carbon mast upgrade; setting him back LESS then US$ 20K. A far cry from the unfounded 35K quotes propelled by some to scare the hens.
In your case (being in Australia) the counterproof is provided by the Aussie Blade F16 as made by http://www.formulacatamarans.com/
European customers have other options such as the Stealth F16 as well.
Therefore, your claims are based on speculation only whereas my statements are based on ACTUAL boats and quotes. If I didn't know any better I would think that you are one of those leaches also known as
stock market trader going short
. You have already created a BP like oil spill on the F16 forum and now you are going full throttle at poisoning the F18 forum as well.
I hope you are really proud of yourself.
Wouter
Posted : May 27, 2010 9:12 am
TEAMVMG
(@TEAMVMG)
That's absurd. who the hell is going to buy a boat that is 20% above the class minimum weight? The next manufacturer to enter the class is just going to produce a lighter boat.
Posted : May 27, 2010 3:45 pm
(@mikeborden)
That hasn't happened yet...
And,
If you'd look at some of the race results(discounting the experts racing), the boat weight doesn't matter.
With today's design's, the weight of the boat and crew doesn't matter as much as it used to such as the Hobie 16.
Mike
Posted : May 27, 2010 4:03 pm
(@mikeborden)
BTW, a lot of people have bought a boat that's 20% above the min weight.
And, there is a boat that's just as new as the Viper and it's a little lighter...AND it hasn't taken the class by storm on finishes as people would suggest.
Again,
It comes down to the person sailing the boat. To many people have it in their heads that a few kilo's makes a BIG difference...
Heck, go look at the Alter cup placement that just happened today.
Some of the lighter teams finished in the middle of the pack and the heavier teams finished higher up. So, what's the problem?
Mike
Posted : May 27, 2010 4:11 pm
(@wouter)
Quote
Actually the preceding four builders (Taipan, Stealth, US Blade, Aussie Blade) were producing lighter boats already. The Falcon launched 1 year after the Viper is also build lighter and the newly launched Aquaraptor is also build lighter.
The Viper, while being a very good boat performance wise, is actually the odd one out.
As a result some people (non F16 class members by the way) now want the F16 class to adjusted its rules to suit the Viper and basically outlaw the other 6 F16 designs. They do so by a slander campaign on the internet that has now unfortunately founds its way to this F18 forum. I have no idea why they feel that they can be successful at that. I am sorry that this spill-over to the F18 forum has occured.
Wouter
Posted : May 28, 2010 4:34 am
(@wouter)
Quote
I fully agree with that statement.
We are seeing a rather flat dependence of performance upon overall weight. A few kg either way is simply too small to result in any measureable speed difference. Of course 10 times
a few kg
resulting in a difference of say 50 kg does eventually give rise to a measureable difference but the Taipan F16, Stealth F16, US Blade F16, Aussie Blade F16, Falcon F16 and Aquaraptor F16 are no where near that much apart. These boats are all enclosed in a range of different boat weights spanning only 5 kg and that is simply too small to matter.
I also think it to be really funny that sailors will think nothing of say 30 kg differences in crew weight and then fuzz about 3 to 5 kg differences in boat weight.
Wouter
Posted : May 28, 2010 8:23 am
Dazz
 Dazz
(@hood)
Wouter
Would you mind defining
they
for me?
Posted : May 28, 2010 11:55 am
NacraKid
(@NacraKid)
I think every one needs to go sailing!
To be honest the F18 and the F16 are both cool boats, I think the viper is a really sick boat (some of the other f16's lack the sexy look a bit lol)
We are all cat sailors, we should all join toghether and not fight each other but beat the crap out those half boat sailors?
Posted : May 28, 2010 1:26 pm
(@mikeborden)
I like that IDEA!!!! <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Posted : May 28, 2010 1:40 pm
Page 2 / 2
