Infusion mainsheet reeving
This is the system that shipped with the Infusion: http:/
This is the best picture I can find, but it's almost impossible to follow:
http://www.murrays.com/mm5/merchant...
Thanks but I was really hoping to find a clear diagram. I do know that the top blocks should be perpendicular to the lower blocks but both top and bottom should rotate freely, right? Harken includes little metal
limiters
that can be used to keep them from rotating. I know I'll want the lower blocks to rotate freely but what about the uppers?
As a tip in the meantime:
Always have the top block at 90deg to the bottom one.
Start at the cleat (through the ratchet backwards)
go through the back sheave on the top block
then on the side sheave on the bottom (from the back side towards the front)
then to the front sheave on the top block
then to the bottom block (side, line goes from front to back)
from here its herd to go wrong, you just follow your way from the back towards the front.
Sorry for asking. Have my boat miles away and need to order new mainsheet. What length are you using (I remember it to be 13.5 meter? but it sounds lengthy) provided you use it back-to-back. Also, am I right in assuming tapering would be arround 3 meters to be able to lock it upwind in full swing and outside tapered area (using normal mast rake).
Cheers,
Jonas
hope this helps
cheers from germany
in case you are looking for a 10:1 combo i can provide a diagram on request.
cheers from germany
Very confusing but perhaps you can make it out from this diagram...failing that send an email to Harken
All help is appreciated
Greetings Form germany
- 6,994 Online
