Infusion snuffer ring twist preventer
F18 Forum
3
Posts
2
Users
0
Reactions
1,626
Views
I'm setting up a new Infusion and am trying to figure out how to connect the provided line line to the hoop to keep it from twisting.
Do I need to drill a hole through the port side of the hoop somewhere? I don't see any other way to tie on to it.
Thanks!
Posted : May 11, 2010 11:26 pm
I think you mean the line that goes to the bridle on the port side?
If so, you need to tie a bowline around the spi pole in front of the ring, then pull the rope into the groove on the ring and lead it to the bridle, it will stay in the groove once its tied to the bridle.
Posted : May 12, 2010 12:07 am
Forum Information
- 2,694 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
