Tiger spinnaker hard to douse
F18 Forum
4
Posts
4
Users
0
Reactions
1,951
Views
What ive learned from top sailors is to hoist the spinnaker (obviously make sure there is not much wind and avoid an accident) then snuff it slowly and start spraying MCLube where the spin makes contact with the ring. Spray generously, I usually end up using an entire can on this project.
Posted : June 23, 2008 12:35 pm
What endpole system are you using? I have my own endpole that works great! Maybe you need to tie a knot to keep the dousing points about 8 inches from each other when they are entering the snuffer.
Are you trying to douse to early? It is actually easier to douse while rounding into the wind, especially with the endpole system.
Holmenkol on the sail works well also.
Later,
Dan
Posted : June 23, 2008 3:14 pm
Forum Information
- 2,124 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
