building foils
I've been looking around trying to find a good site that not only has step-by-step instructions but also pix and diagrams on how to hot wire foils. Does anyone have some good info or website addresses? Im not sold on hot wire methods , so if you have a bette plan, let me know.
Dave Mosley
some time back, Kevin Cook did a pretty extensive post on building foils. It was on the old forum, see if you can find it, or if someone has saved it. I can say first hand that the method he describes builds some of the best looking foils I've ever seen (he built the ones on my boat as well as the boat itself). Good luck and good sailing!!
TB
The following was posted by Phill Brander on the old forum some time a go.
I saved it for future reference.
He has pictures on his Web Site:
http://www.geocities.com/phillbrander/
Low Tech Carbon Foils
Posted by Phill Brander on December 29, 19100 at 05:28:04:
Just in case there are any peple out there wanting to have a go at making some light weight foils.
I've posted some pics on my web page (under
Chined Construction
) of the boards I'm building. They really quite light and incredibley stiff.
The way I went about it is as follows:-
The rudders and centreboards I made by plotting a NACA 63009 section onto a section of aluminium for each. Then I filed it to that profile.
I screwed this to a peice of cedar and used a router with a ball bearing bit to cut the cedar to the shape. Then glued some 100grit sandpaper to the cedar. This is to shape the foam.
I used styrofoam rated at 300kpa. Ordered a 50mm sheet cut into 3 8mm sheets and 2 10mm sheets. Used the 8mm for the rudders and 10mm for the centreboards.
So I obtained a sheet of plate glass. Applied some PVA as a release agent.
Wet out some 6oz glass and vacuum bagged the foam to the glass. Then I set up a jig and used my cedar block with sandpaper to shape the foam. The glass backing stabilised the foam and allowed me to get really good trailing edges.
Once this was done I routed out the foam of each rudder half where the rudder passes below the rudder stock and replaced it with cedar as a core that tapers away several inches below the rudder stock and goes up to the top of the rudder.
The rudder layup was one layer at +36deg and one at -36deg, top to bottom.
One layer straingth down the foil top to bottom and one layer straight but only
half way down. Then one layer of 6oz plain weave glass over the carbon.(just something to sand when finishing them instead of weakening the carbon)
Anyhow I vacuum bagged the layup and then cut away the 6oz glass and 20mm of foam from the leading edge of the rudder and bottom and filled this with glue before vacuuming the halves together.
The sectional shape is exactly the same as my aluminium profile over the length of the blade.
Both rudders and centreboards seem really true.
They should be as true as the plate glass I used to vacuum them against. At least that was my theory.
The layup of the centre boards was similar but I used end grain balsa where they pass through the bottom of the hull. Also the top of the board has only two layers of carbon as does the bottom while there is 4 layers where the board goes through the hull.
I used 8 metres of 300gm uni for two rudders and another 8 metres for the two centreboards. (They weigh about the same.)
The centreboards are 960mm long 210mm wide and weigh 1250 grams but they still need the top coat of polyurethane. But that won't add much weight. I doubt it will add much more than 50 grams.
Phill
Later,
e
My reference site for everything that relates to foils is Phil's Foils page. He has lots of links to get every aspects of subject
http://www.magma.ca/~locker/foils/
Franco P-19 45 (would need new foils !)
Everything about foils can be found in www.foils.org - International Hydrofoil Society.
Take a look.
Luiz
- 2,852 Online
