Carbon & UV?
(@tornadokc247)
[#12723]
Do carbon spin poles etc need to be protected from the sun during boat storage? If so, is painting them a solution rather than making some kind of cover?
Posted : October 15, 2003 7:23 pm
(@Anonymous 13024)
Yes, all carbon/epoxy parts need protection from UV. You can paint the parts, give them some layers of clear UV filtering finish or use a cover.
If you worry about your new Marstrøm parts, check with Sailcenter about an UV filter already applied.
Posted : October 16, 2003 1:50 am
(@tornadokc247)
Actually, the pole & snuffer on my Marstrom is from Guck Inc. in Rhode Island. I'll have to figure something out.
Posted : October 16, 2003 4:34 pm
bvining
(@bvining)
check out SystemThree WR-LPU two part polyurethane topcoat. clear gloss, thins with water, cleans up with soap and water, according to SystemThree it stops UV damage to your expoxy/carbon stuff.
Posted : October 16, 2003 4:52 pm
(@kbcatman)
Chesapeake Light Craft uses a couple of coats of varnish over their clear epoxy construction.
Posted : October 16, 2003 5:19 pm
(@Anonymous 14038)
It depends on how they are made.
Pre preg have UV inhibitor in the resin.
Wet layup will usually need to be protected although I think West are now selling a hardener with UV inhibitor in it. Other manufacturers may also have this. Basically you need to find out what it was made from.
Posted : October 16, 2003 8:32 pm
(@Anonymous 656)
Let me get this strait. Carbon is affected by UV rays. Does that put the used boat buyer at risk in a few years?
Posted : October 17, 2003 8:11 am
Jake Kohl
(@jake)
My understanding is that it's not so much the carbon as it is the epoxy that holds it all together. Yes, if there is not a UV protector added then it will suffer frmo UV exposure.
Posted : October 17, 2003 8:33 am
(@tornadokc247)
Only if the carbon boat is unpainted or the spars are unpainted/varnised...Is this even an option?
Posted : October 20, 2003 2:30 pm
