Cat Trax Tires
11 Users
(@john5583)
[#26647]
Anyone have a line on where I can get JUST the tire? Check Rick's store, N/A need to get tire and rim.
Posted : April 1, 2010 5:25 pm
(@hullflyer)
Florida
sailcraft 954=523=9222
Posted : April 1, 2010 6:16 pm
(@john5583)
Originally Posted by Hullflyer1
Florida
Same thing, tire and rim only. And Murray's too.
Posted : April 1, 2010 6:35 pm
(@_removed-account)
Four Star Admiral Registered
The only thing I can suggest is what used to be Hedlund Marine in Evanston, IL. I know they have stocked cat trax in the past.
Posted : April 1, 2010 7:08 pm
(@Anonymous 457)
Maybe check on agriculture/farm supply web sites? Ed
Posted : April 1, 2010 8:15 pm
Dazz
 Dazz
(@hood)
https://store.catsailor.com/pc/viewPrd.asp?idproduct=14568&idcategory=287
fsc-tireonly Cat Trax tire Only, (Subtract $45.00 from Listeed Price)
so what do I win?
Posted : April 2, 2010 2:13 am
(@edgarapoe)
I was going to say, we have the tire ONLY,
Rick
Posted : April 2, 2010 9:57 am
(@brucat)
I don't know if it's BS or not, but I was told by my dealer that the newer tires weren't compatable with older rims (my Cat Trax are from 97, I replaced the tires with rims sometime around 2006).
I've also seen some discussion here about getting tubes if the tires are basically OK just not holding air.
Hope this helps.
Mike
Posted : April 2, 2010 11:26 am
(@jeremyleonard)
Hope this helps.
Mike
If your tires are even in marginal shape, tubes will solve the problem. Make sure to get the ones with stainless valve stems, and dab a little Lanocote where the rim comes into contact with the stem. Once you get the tire off of the axle, set the rim on its side hold onto something and stomp on the bead with your foot to break it. Install tube, and off you go.
Posted : April 2, 2010 11:43 am
(@edgarapoe)
I put tubes in both my Cat Trax and Euros (plastic Rim) and my headaches disappeared. Otherwise they were always going flat.
We sell the tubes also, by the way, and fit both.
Rick
Posted : April 2, 2010 3:36 pm
 Karl
(@sogncab)
Yeah, if you're a 6'4" freak that works. I used the bucket of the skidloader to bust the bead on a set I had.
If the tire is still there, a tube is a pretty good way to fix it.
Posted : April 2, 2010 4:42 pm
(@john5583)
Just did it, busted the bead that is. Now about that diet I have been meaning to get on.
Posted : April 2, 2010 4:50 pm
(@Anonymous 39709)
The Ventura boat ramp not working anymore John?
Posted : April 2, 2010 4:52 pm
(@jeremyleonard)
<img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
It helps for sure.
I showed up to a meeting at a Yacht Club the other day full of people that were talking smack on something I wrote. Several of them PM'd me with a big F-off. I sat in the back sipping a rum and coke, just listening. When the commodore introduced me to the group, their jaws dropped, their eyes bugged, out and the **** immediately stopped slinging. Another instance where being big is an advantage. Bad for cat sailing though.
If you've met me in person you'd know that half the stuff I type is with a smile and a twinkle in my eye. No sense in being too serious, you know.
Hijack off. Good luck with the wheel dilemma.
j
Posted : April 2, 2010 5:06 pm
F-18 5150
(@hobie18rich)
He's just a long haired red headed Baby Hughey
Posted : April 2, 2010 6:29 pm
(@tornadokc247)
Johnm-Boy, If you're ordering a set of tubes...I'd like to double it wit ya...got a slow leak on one tire...
Posted : April 2, 2010 6:30 pm
(@john5583)
Check your PM.
Santa Barabara!!!!!!!
Posted : April 2, 2010 6:56 pm
(@edgarapoe)
Hmm! Guess I am a candy butt. Took mine to the local garage.., cost $5.
Had I done it myself, I probably would have destroyed the tire, tube and rim in the process, and would have cost a lot more.
Rick
Posted : April 3, 2010 7:14 am
(@Anonymous 14670)
Try changing out your valve stems first. They only cost about $3.00 and with a little soapy water and some effort you can probably fix the problem if its a slow leak.
Did it with one that came with my boat, the schrader valve was corroded and wouldn't seal completely. Cut the old ones off, slapped some new ones in and haven't had a problem since.
Posted : April 11, 2010 6:59 pm
(@Anonymous 37755)
The last time I had a leaky tire I pulled the old valve stem out, dumped a 16 oz bottle of Slime in, and put the new valve stem in. When I inflated the tire, green stuff came out from the bead, for while. That was 6 years ago. No leaks since
Posted : April 12, 2010 10:13 am
(@Anonymous 87)
John I replaced both my tires last year at J and J Tires in Canoga Park Ca. Took a day to get the tires and cost $50 each.
Buzz
Posted : April 12, 2010 11:29 am
