I had to relist again on EBAY..but now you will always find the good Ebay adress at this place :
http:/
Open the txt file to find the ebay address.
Thank's
What region is the DVD ?
See this list
2: Japan, Europe, South Africa, and Middle East (including Egypt)
3: Southeast Asia and East Asia (including Hong Kong)
4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
6: China
7: Reserved
8: Special international venues (airplanes, cruise ships, etc.)
And region 0 is free of all restrictions.
Depending on the DVD player, it may have a physical lock indicating which region DVD's it will play.
Or it may have a software lock (Arcam for one are like this
Do a google for "DVD type"+region+hack and you might find the appropiate software code to add.
I cannot be certian that a hack will exist, or if there are any risks in using these. All I know is that I have hacked my Arcam DV88P to be region Zero and it will play anyhing
Well I bought a new DVD player $159.oo
I had to try a bunch of players at Circuit City to find one that worked.
In the manual it says that the player will work for Region 1 DVD’s and for DVD’s that do not specify a Region. I think most DVD players in the US only play Region 1 DVD’s.
Since this DVD works on this player I’m guessing that there is no region code specified on the DVD.
The video is great but at a total cost of over 200 bucks it’s hard to recommend it.
After doing all the hard work I’d think they would be able to sell DVD’s in Region Code 1. Hopefully they will figure it out.
DVD region codes are the problem. An earlier poster described what you can encounter. Suggest following his instructions on googling your "player model/hack/codes" to locate one of the sites with info on your player. Some of the manufacturers may also provide a fix DVD.
Below is a site link that may help out.
Sail fast, Tom G
Sail fast, Tom G
It was I, about 6 posts back
Ok I've been looking for away to get a couple of young people involved in catsailing. Today I showed the dvd [on my computer still can't make it work on the TV] in total. All I heard was WHEN DO I GET TO GO??? Thanks for making this simple enough for a newbie to follow. Also my goddaughter is quoting Booths comment about strength being 10%...Great job!!!
thom
Ordered the DVD and I agree, it is great!!
Encountered the same region play problems though. Here is what my research found:
1. USA produced/destined DVD players are mostly restricted to play region 1 coded DVD's only. Some existing inventory stock may still play without restrictions but the newer units are moving towards coding by region. Thank the movie industry for this one.
2. Windows PC based DVD players will allow up to 5 region code play changes and then will lock onto the last DVD code played (thanks to Bill Gates for this one).
I have 3 newer DVD players and one PC based unit. None of the DVD players will work (all are region 1 only). The PC unit does but I need to use due care so I don't lock it out of region 1 DVD's.
Some DVD player models remain "soft encoded" so you are able to use hack codes to over-ride the lockout. Newer units are hard wired so you cannot over-ride. I did confirm with Panasonic, Pioneer, Best Buy and one of the local factory authorized repair shops.
If you are buying you may be able to snatch up a region 0 (all regions) player. They are also offered on the Internet with the region encoding over-ridden.
I have communicated with the producer and they are working on a region 1 release. I have been advised one will be available in about 30-60 days.
Hope this helps.
Sail fast, Tom G
- 626 Online
..... Alchole induced dissy spells
