Dagger Board Height Control
(@Anonymous 39549)
[#29776]
Has anyone adapted the AC45/AC72 dagger board vertical adjusting systems for smaller boats? It sure seems better than sending the crew to the bottom of the boat to adjust them.
Posted : May 27, 2013 5:47 pm
(@_removed-account)
Four Star Admiral Registered
Um the AC45s are adjusted at the board basically like ours.
The AC72 use hydraulics and goffee grinder pumps to adjust theirs. I can't see that catching on on a beach cat.
Lots of beach cats have the control line cross over so you can at least raise the board from the wrong side.
Posted : May 27, 2013 6:55 pm
Tony_F18
(@Tony_FX1)
Search for
upf*cker
Posted : May 28, 2013 3:14 am
Jake Kohl
(@jake)
we do something similar - a lot of a-cats and many F16/18 boats have a hole drilled mid-way through the daggerboard. A line or nylon strap goes through that hole and is knotted on the end. It is dimensioned such that the hole/line is still in the hull trunk when the board is fully down. You just have to pull the line/strap and the board will come up to about the halfway point.
Posted : May 28, 2013 7:14 am
 samc
(@samc)
Using this system over the weekend it has its limits, raising the weather board from the wire is an issue for example. Having a monkey crewing for you really helps. I talked to Tripp a bit about what they do, essentially there is a block on the side stays above the max board height. A line goes from the top of the board, up through the side stay block, back down to a turning block on the bottom of the stay, across the boat and repeated on the other side. A 2:1 system may be placed in the loop, all similar to the AC45 system.
Posted : May 28, 2013 10:32 am
