Diamond Wire Settings
10 Users
(@john5583)
[#30473]
I replace my diamond wires and stupid me forgot to take a reading before taking them off... And I liked the setting....
I have found a few settings on line of 176 KGS/ 390 LBS Setting #28 on the Loos Gaudge, but that seems a light.
Any other benchmarks to consider?
Boat = 2003 NACRA F-18
Crew = on average 440 lbs.... I know... to big old guys
Wind = on average 10 to 15 kts steady
Water = general ocean sailing... moderate chop
Posted : August 12, 2014 4:30 pm
Tony_F18
(@Tony_FX1)
The Infusion tuning guide is probably a good start:
http://www.nacrasailing.com/wp-content/uploads/pdf/nacra-f18-infusion-trimsheet-5.pdf
Posted : August 12, 2014 4:39 pm
(@john5583)
Tony,
Thanks.... I have looked at that and have been told that they are two different mast profiles which sort of negates the recommendation... Am I getting wrong info?
Posted : August 12, 2014 4:52 pm
Jake Kohl
(@jake)
Originally Posted by Ventucky Red
Tony,
They are very different masts. While I wouldn't be surprised if the average settings work out very similarly (since the load capacity of the wire systems are likely very similar), I would consult the sailmaker for the recommended diamond wire settings. I had that version of F18 but really can't remember anything about how we used to setup the diamond wires.
Posted : August 12, 2014 5:10 pm
(@Anonymous 15703)
It's a bit complicated with that boat, the bottom of the diamond wires was attached in different positions, some were at the front some at the side at various distances from the leading edge. If you haven't changed your spreader rake, start at 40 and go as high as 45 on the Loos guage. You have to have prebend with that mast so if 40 doesn't look like much you could add a bit more, mostly the difference will be your sailing weight. For detailed help you could email Rosco or Warren at
Brisbane Catamaran Centre
in Australia with measurements of your setup including the position of your spreaders, how long they are, what the spreader rake is and your exact attachment point at the bottom.
Posted : August 12, 2014 7:07 pm
(@john5583)
Yes it is a little tricky...
Found some info from Goose Marine on tuning the 2003-2005 F-18... https://store-cpjif3z.mybigcommerce.com/content/Tuning-guide-F18-2003-Model.pdf
Then there is the
which Loos Gauge
factor... For instance I am using the PT-1 standard and I believe many folks are referring to the Model A tool metric.... not that 3 mm and 1/8" are any different... but the Loos #'s are
So starting at 40 on the model A would be 250 KGS that translates to 550 lbs which is just about 30% of break strength... Looks like 177 KGS/390 LBS should be a good starting point....
I will drop Rosco and Warren a note and get their advice too.... Appreciate your help..
Posted : August 12, 2014 9:14 pm
(@_removed-account)
Four Star Admiral Registered
There is a 6% difference in diameter and an 11% difference in area (the important number).
Posted : August 13, 2014 1:49 am
Jake Kohl
(@jake)
Then there is the
which Loos Gauge
The engineer in my absolutely hates it when people use the numbers off a particular loos gauge as the reading. There is a conversion scale on the side of that thing for a reason. lbs or kgs tension is THE measurement to use to make notes or communicate that reading. It is the only measurement that is scientific and standard.
Posted : August 13, 2014 7:52 am
(@isotope42)
Does that mean the engineer in you doesn't absolutely hate it when people use units of weight (lb) and mass(kg) when they should use units of force (lbf and N) to measure tension? After, all, force units are the measurement that is
. <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
Posted : August 13, 2014 8:25 am
(@john5583)
I agree, just give me the KGS or LBS setting.... as I found out yesterday there are a few different Loos gauges in the market and each of them have a different scale.... But as person put to me recently
it needs to be dumbed down because people don't want to think anymore.
Isotope.... I am not an engineer, but close.... I love to work on cars and such... hells bells, I'll rip out my VW engine and rebuild it for fun even though it just got broken in from the last rebuild... In my years I have always thought torque and tension (which is what I believe I am measuring with the diamond wires) are two different things.... Is this not the case
As a side note, in college when taking German, we had to translate a book chapter from English to German.... I decided to do the chapter from "How to Keep Your VW Alive.... specifically the engine installation procedure.... had to convert all the Pounds to Newtons setting using paper and pencil.... Pocket calculators we're just coming into the market and we're selling for $100 plus.... Yes..... I am that old!!!!!
Posted : August 13, 2014 9:00 am
Jake Kohl
(@jake)
{facepalm}, yes, that. I had a coworker throwing up next to me twice this morning before I was able to demand that she go home (I was on two different conference calls with clients at the time and they were listening to it too)....that threw me off my game a little this morning ;-)....although, in my defense, the gauges do list their scales in
lbs tension
or
kg tension
...which I think is still technically correct since it's measured in a static condition and we're not concerned about the effects gravity in this case? I would have to look that up.
Posted : August 13, 2014 10:06 am
(@stank)
One Star Admiral Registered
If you'd hook us all up with the inline digital force transducer you've likely engineered (from the AC boats), we wouldn't have to use the stone-age Loos gauges!
And I am absolutely sure that flux capacitor you built for that Everglades Challenge boat to your F18 is not class legal... Not to mention your cloaking device
Posted : August 13, 2014 11:02 am
(@david.ingram)
Ok you guys it really is time for you to out of your mom's basement.
Posted : August 13, 2014 12:10 pm
(@john5583)
Hmmm this is giving me some ideas!
are any different
As we say here in the US...
good enough for government work."
Posted : August 13, 2014 12:14 pm
(@stank)
I'm grounded till Buzzelli.... (but I did register bit*hes!)
Posted : August 13, 2014 1:25 pm
(@catman)
LOL,
That sounds like like a Jersey comment.
I'm sure your response will be,
TOUCHE
Posted : August 13, 2014 1:26 pm
Jake Kohl
(@jake)
No need to engineer it, Harken already makes one using a high resolution strain gauge (much more accurate that an uncalibratable simple spring loos gauge).
[Linked Image]
Posted : August 13, 2014 1:56 pm
(@john5583)
Originally Posted by catman
Quote
LOL,
TOUCHE
Actually leaned that in California.... along with close enough for horseshoes and hand grenades...
Posted : August 13, 2014 4:25 pm
Dazz
 Dazz
(@hood)
[Linked Image]
you mean Harken USED to make one, discontinued...
Posted : August 13, 2014 6:12 pm
