HOBIE 18 COMPTIP REPAIR HELP
2 Users
(@Anonymous 1624)
[#12307]
HELLO THERE
Yesterday I installed a Hobie Bob on the tip of my mast. while installing the rivets some little (1/4") cracks occurred from the pressure of the rivet gun. I think that if I take a spill the impact may actuallyrip the rivets off at these cracks. Is there something I can use to fill these cracks and strengthen this area?? maybe some kind of compound? also, should I seal around the rivets with something so that water does not go in??
thanks
fred
Hobie 18
Posted : July 21, 2003 6:33 pm
(@mauganh17)
I'd use an epoxy resin, and try to seal the cracks like that.
and yes, you should put sealant in the hole before puttin in the rivets to seal it.
Posted : July 21, 2003 10:37 pm
