N6.0 original or N6.0 NA?
When I bought my N6.0, It was an original. I snapped the mast off a couple months ago and replaced it with a mast with double diamond wires(NA mast). I still have a small square top main(sq footage in line with 6.0 orig),a self tacking Jib, and a spinnaker. Is my boat considered a NA, or an Orig.? Also, If it is an NA, and I opt to get a larger main, can I make up some of the lost sf from the self tacking jib and add it to the overall sf if the boat(by adding over 3% to the main?
BTW, we had a mixed regatta with the local (Phoenix and Tucson, AZ) Hobie fleets in rocky point Mexico over the weekend. Had around 40 masts on the beach. This was very exiting to see as numbers have been dwindling over the past years. Thanks to the Hobie fleets for including our
all cat's
fleet in their lineup. I am looking forward to more of the same this spring for the PiƱata Regatta in April and for years to come. All cats, as it should be!
you still have a frankenboat. To properly use the DPN, you need to take the correction factor for a smaller jib and a larger non-factory main (they are in there for both). the DPN correction factor does not take into account moving sail area from the jib to the main and calling it
even
(although, it's possible the correction factors will come out very close that way - I haven't looked to see).
Frankenboat factors;
The original 6.0na pinhead had a section of sail that went to the bottom of the mast.(you can do that with boomless rigs). With that removed and a samll amount off the leach you can build a nice squarehead and stay within the same sail area of 6.0na sail area. This is only a .995 hit. According to the tables Same Sail Area: within 5% of Calculated Approximate Sail Area .
You get nothin for downsizing the jib. Only if you remove it.
The other option(providing the self tacking jib is the same size as the 6.0 original) is rate as a 6.0 original with a larger main and take the .980 hit.
If you have a spin you take a .960 hit.
You also have to take a .995 hit for the selftacking jib. Does not matter if the size is the same it is a mod from the original one-design. See this section:
Other
Any other deviations from standard class configurations, including the addition of wings, can be assessed a penalty of at least 0.995. Multiple deviations may incur multiple penalties. Penalties may be greater than 0.995. Please identify any such modifications and penalties assigned and include with results reported to the handicap committee and Portsmouth Numbers Committee.
To clarify, this can't be done. The original is an overlapping jib.
The difference between the NA and the original was the addition of the bridal foil complimented with the larger jib.
The 6.0 always had the foil. Although at first it was a round bar rather than foil shaped. The original had the self tacker only with a straight track, it really doesn't work well if you sheet the jib in too much. The N/A had the overlapping jib, bigger main and double diamonds.
no kidding? The original 6.0 had a self tacker? I did not know that.
This boat has an interesting history. The original owner bought it new to do the Worrell and never did it. There were about 8 of these made by Roy Seaman that is boats with self tackers, spinnaler set up and a few other goodies. This boat sat in a warehouse for a number of years and then the owner sold it.
I looked at another 6.0 NA recently that was the stock set up with no self tacker.
make you slap your mama
on a reach.
Nothing like a 5.8N/A or a 6.0 on a screaming reach with that big ole jib.
AZCats boat one of kind, well in his case 8 of a kind.
There are a few other 6.0's running around here we refer to as Roy's Toys. There is one where he had moved the bridal tangs to the front of the bows with a custom made slag of stainless steel the looked like something out of Mad Max, put a gargantuan jib on it, raked the dickens out of the mast, and swore it didn't need a spinnaker. I seem to recall Team Chums beating him back with his H21 w/spinnaker - he just forgot to take in down once inside the harbor and got disqualified from the race. There is another one where he took a 5.8 (the boat he designed) lengthened it to a 6.0 gave it 9.5 foot beam - the true Frankinboat. One day the owner and I took it out and drove it hard, that thing hauled butt!!!
I too owned a N6.0na. I always thought that the original N6.0 had a slightly smaller mast, and a standard bridle for the jib, (no foil) that sheeted to the front crossbar on a straight track, not a curved one. I have only seen one of them, and really don't remember where or when.
If the boat were mine, I would probably call it a 6.0 original with a replacement mast. I am not sure if they could hit you for .995 for the taller mast. The rules for the 6.0 were pretty open. There was a version called the Prosail 20. I am pretty sure I saw a Prosail 20 with a double diamond mast. I would look at the rules for the 6.0 original and the Prosail 20.
If I remember correctly, the sailmaker for the original 6.0 was open. So, a first rate set of 6.0 racing sails would not carry any penalty. You might ask EP what they think.
My experiments showed the original jib pointed higher than the big jib on the 6.0na. Since we rarely run a B mark anymore, the speed on a reach doesn't help in a race.
Enjoy your boat. It's unique and a bit of history
Lee, I already added a curved jib travler, love it. Also added the high aspect sq top main and new jib . I raced over the weekend and was rated as a NA because I recently snapped a mast and replaced it with a new NA mast. Wondered if that was right. The jib is about the same size as the boats original jib, and the main is not much bigger that original.
While I have your attention, I have another question that you may be able to help me with.
I am rinning an F-18 spin. Whenever the wind is over, say, 13mph, as I come out of a jibe(or set the spin), I turn up until the spin fully powers up, and then attempt to turn down.
I cant figure out if the crew is stalling the spin until I am too close to a reach (i always end up with different crew- in experienced), I cant see the tell tales from helm, Once it powers up,
Wet Kitty
wants to launch me like a catapult over the top of the mast unto the water.
When I feel the spin power up, i pull on the tiller and try to turn down, but it is nearly always too late. Windward hull rises very quick;ly, bow submerges immediately, OOOOH S@#$! I nearly capsize way too often. The boat just dosnt seem to power up until I am way too close to a reach.
If the crew lets out the sheet till the spin starts running when I am pointed more down wind, the luff collapses as soon as we start powering up. And we never seem to fully power up even if they can sheet it till the tells are streaming.
WTF am I doing wrong, or not fast enough?
BTW, total crew weight is around #380 on average.
Sounds like your crew has it over sheeted and you gotta come to high to get the airflow attached again, then the hull pops up dramatically. Crew should ease the chute more while you two heat the boat and sail back up together. Like you guys are meeting halfway to get going again. Did you put on a spinn pole that is the right length? Which F18 was the chute made for? How tight is your luff tension when it's up? Should be a 45* to 90* turn with your fist on the luff when sheeted in. Lots of variables here and I hope others can chime in. I'll be on the road to Annapolis for the next two days.
AZCAT why don't ya'll bring the little pussy (cat) on over to Ventucky where the wind blows dogs of chains, and we'll drive that bad boy like no ones business.
Next time I head to PHX on business I'll look ya up maybe we can get some water time.
Shoot me a PM
yup. Tell the crew to ease off the lazy sheet a little longer and sail the kite through as much of the gybe as possible. That WaaahhhBahhh-YeeeHaaaw is a good way to put it pointy side in.
PS - I hate tales on the spinnaker. I think they're misleading and you do better by learning to feel how the kite is pulling and by the shape of the luff....but then again, it might have been that 540 miles I sailed for Carl Roberts when every 3 minutes I was asked if the tales were flowing on the kite (which they usually were - even when sheeted to high heaven). I definitely disliked tales on the spin after that. š
The chute is off a Nacra f-18. Pole is 11'4
to the tip of the end pole hoop.
As fat as luff tension, I was pulling it all the way p and then letting off about 6
, This put a lot of curl in the luff so I let it off till the sail flattened out ( about 18" ) seemed to help some the next day, but the winds were lighter also.
I will set it as you describe next time I go out and will mark the sheet.
Jake, thats the feeling Im getting also. If you cant tell when that chute fires up, theres something else going on. I think that the tells may have ben flowing so crew thought the chute was running, but it was still stalling. I told him
when in doubt, let it out
. I think he was still stalling the sail.
Once the sail woild start to run,the luff would fold up, so I guess he needed to sheet it in faster. We were racing with non spin and they would just about keep up unless I really heated it up by going way high. Then we had other problems, like swating dolphins with the tip of the mast.
I have never crewed for anyone on a cat before, and I dont know many people here that I would trust with my tiller, or that are experienced whatsoever with headsails in these parts.
Lee, I sent Matt an invitation to skipper/crew for the RPC regatta over this last weekend, never got a response. I think he may be the only person that I would trust to skip and show me the ropes here in the valley. I beleive that the last time he was on a cat was when he did the
Border Run
two years ago on his Tiger.(and left us in the dust.) Thought he may want to get his eye sockets wet again.
There may be one other person that I sail with on a regular basis that may be able to handle the boat, but he is not experienced with a chute.
I think this will turn out to be a case of needing to get the same experienced person on the boat repeatedly so that I can figure this bad boy out.
There is going to be a degree of the crew having to bring the kite in as the boat accelerates out of the gybe. The trick is doing it AS the boat accelerates. The better the two of you get at gybes, the faster you can turn, then the less the boat decelerates and the less the spinnaker trim will change during the maneuver. Until then, soft set early, trim quickly with acceleration.
Hey Kitty I used to own that boat and it is one of eight built for the Worrell. When I had it it had a kevlar main with the number 8 on it and a hugh spinnaker with big shoulders. If you are looking for someone to help you with the spinnaker you might look up Mark Corby. He had a beautiful Nacra 5.2 with spinnaker, a P19 with hooter, P19MX with spinn, and a Tornado with spinn.
Buzz
It still had its Kevlar main and jib when i got it. The sails were like new. Mine carried #37 on the main, I kept the sail # with the new sails. the kevlars went down hill pretty fast, delamination and 23 years. I still have the Spinnaker. When I bought the boat I had to check it out, and I believe that I was the first person to look at it since it was folded up at EP. it came with all of the rigging to run the spin , lines, blocks, haulyard, sheet,, cleats, and a hand sketched diagram of how it should be installed on the boat. everything still in its original pacaging. I would love to fly that spin sometime, ned to have patches sewn on and see if it wil snuff. It's a monster. I believe its 350 sf.
I do talk to Mark now and again at his store in Glendale. Bought a mast caddie from him and have talked cats a bit in the past. Maby I'll bring it up next time I need bolts.
since we're talking about spinnakers & trimming correctly, how would you generalize good trim from a crew perspective?
Originally I had suspected that trimming it so the luff was near collapse (but not so) when headed down was most efficient. Is this still the case, or are spin cuts so different these days (versus 5 years ago) that you fly them entirely different?
Buzz
This boat was in a warehouse not to far from you when I looked at four years ago.
Keith, I had to deliver a Zodiac to Oxford for the Opti Regatta. Non stop drive from Houston then to the airport.
Azcat, one other thing to consider is lengthening your bridal wires about 3 inches to get some more rake in the mast. This may help balance the rig out more now that there is a spinn on it. PM me and I'll give you Anthony Aquilla's number. He lives in phx and used to be my number one crew. I wish I could have got him to do the Tybee with me atleast once. Matt may be pretty busy right now with the new baby and all, dont take it personal. When I come through Phx again maybe we can rig it up and go for a sail. I should be coming through early Nov.
Just make sure you get my Inter 20 to Ventucky first!!!!!
- 5,911 Online
