Nacra F18 dagger board stop material
The material that was used for the dagger board stop, which will hold it in position when I change setting or pull it up to beach the boat has worn out and cracked due to age and material fatigue. Can anyone tell me what to use for replacement. I considered using the Hobie Tiger parts, but I am not sure if they would work. Getting factory parts from the Netherlands appears to be a major undertaking.
Posted : February 19, 2014 8:54 am
Have you checked with a local dealer (I presume you are talking about a Nacra?). This is a very common item and most should have it on hand.
Posted : February 19, 2014 10:05 am
Is that what you are looking for?
http://www.murrays.com/mm5/merchant...
Posted : February 19, 2014 12:48 pm
Forum Information
- 1,356 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
