[Prindle 19] Holes in mast
Hi all,
After a few years of sailing with friends, I bought my own catamaran. This cat is not used in recent years, and needs some maintenance before the season starts.
There are two holes at the base of the mast (7 and 8 mm) that I thought where missing rivets however, I cannot find rivets in that size can someone tell me what belongs in this holes or how I can fix this?
Also, there are two bolts from the rear beam bent I've already looked at Murrays but I'm not sure which one i need. i need the countersunks bolts and the normal bolts are these deliverid complete? so including nylon spacer washer and nut?
thanks
I don't think anything bad will happen if you live it like that, it's more an aesthetic repair to me. Maybe just use that duct tape on the picture.. The only way to fill the mast with water from that hole is if you turtle, but that is not supposed to happen. And if it happens most likely there will be water inside already.
Forego the rivet and just use 5200. All you really need to do is seal the mast.DO NOT put a stainless steel bolt or rivet in the hole just to fill it. Stainless will cause galvanic reaction and you don't need the strength of stainless for anything in that repair.
- 1,362 Online
![[Linked Image]](http://i61.tinypic.com/n52b9x.jpg)
![[Linked Image]](http://i60.tinypic.com/kbar20.jpg)
