New A-Cat Worlds Story, Pix and Results -Tues
9 Users
(@edgarapoe)
[#21343]
Story, pictures, results all up and running. Go to www.catsailor.com or click on logo in upper left corner.
Rick
Posted : November 13, 2007 5:08 pm
(@catfan)
In the official results Mitch Booth is scored 12/RDG in the 4th race and not OCS as you wrote.
Can you explain what's happened in the evening?
Posted : November 14, 2007 3:06 am
(@edgarapoe)
Nope, I am not there in the evening. Busy getting stories and pictures done, so I get to miss all the political hoopla. <img src=
Rick
Posted : November 14, 2007 8:57 am
(@mbounds)
From the SA Reporter:
Quote
One competitor was scored RDG for being over early and having the International Jury rule to adjust his finishing place based on the fact that the RC Signal Boat was a few seconds late in raising the Indivitual Recall Flag. When I say a few seconds, I mean more like 1-3 seconds later thant the 2-6 seconds they rule is the standard for raising the IR. The Jury's ruling was fair and based on the facts. But, the body of the Competitors feel that when a competitor admits in front of a Jury that he was OCS that the hearing should have ended with that as the result. Unfortunately, the individual who filed is a known Sea Lawyer type who has a long history not only with fleets but with National Authorities. The RC had its hands tied because the detailed documentation indicated that they were a couple of seconds late with the flag. The Jury had to rule on the facts found.
Posted : November 14, 2007 12:02 pm
(@Anonymous 32191)
WOW sportsmanship personified.There was a quote I remember from a pretty descent sailor(Paul Elvstrom)
if you win and in so doing lose the respect of your fellow competitors,you really have not won anything at all
Posted : November 14, 2007 12:11 pm
MaryAWells
(@maryawells)
Wednesday, Day 3:
Winds light, 6-7 knots, occasionally dipping down close to the 5 knot minmum, out of the North-Northeast.
1st race of the day, positions 1st time around the weather mark:
1. Ashby
2. Booth
3. Guck
4. Pease Glaser
5. Daniel
6. Melvin
7. Pieter Saarberg, NED
8. Ogletree
9. Ian Lindahl, USA
10. Callabria
11. Kinder
12. Thomas Persson, SWE
13. Tracy Oliver, USA
14. Cope
(NOTE: Not sure what happened, but the first race was started for the first time, it was abandoned when the boats were halfway up the weather leg. Powerboats went and rounded them up and sent them back to the starting line. When they tried the start again, there was a general recall, and the third try was under black flag. That third start was successful.)
Posted : November 14, 2007 12:14 pm
MaryAWells
(@maryawells)
Second time around the weather mark:
1. Ashby
2. Melvin
3. Booth
4. P. Glaser
5. Guck
6. Ogletree
7. Saarberg
8. Kinder
9. Callabria
10. Daniel
11. Persson
12. Cope
13. Philpott
(NOTE: Wind is down around 5 knots now.)
Posted : November 14, 2007 12:29 pm
(@tomsiders)
Report by Brian Hawbodlt:
Grass, grass, grass… Recent storms that have rolled through the Florida Keys have washed a lot of shallow water sea grass up on shore and a change of wind carried the grass out into the Atlantic by way of the channels. Well, guess what? The A-Cats are racing both outside of a channel that cuts between a couple of the Key Islands and the racing area is located smack dab in the middle of the main Atlantic inshore channel that runs the length of the Keys. So what we saw on the course today was a lot of grass drifting downwind through the course. Oh it’s not as bad as it sounds, we could be sailing off of San Diego where the kelp will stop a boat cold dead in its tracks. But for a fleet that was expecting beautiful tropical sailing in the Florida Keys in the late Fall, the floating grass was frustrating for everyone. But, taken in the gestalt of everything, grass was fair and frustrating for everyone equally. The Race Committee drove around the racing area trying to find the most grass free zone and settled in for the first race. Before the start of the second race , the RC sent out a scout boat to try and find a different location to move the course. Unfortunately, the entire area had floating grass in varying thickness – from clear and weed free to floating palm fronds in clumps with entangled weed. Some competitors had rudder assemblies that enabled them to yank a line to raise one or both to easily clear. Most though had rudders that had to be raised manually and individually which made clearing the grass more problematic. There were some boats with “short boards” that could be easily pulled up to clear the weed, and some that had a more difficult time raising daggerboards to clear them. Overall, the grass was equitably challenging to all competitors. Check out the Day 2 Results at http://www.acatworlds.com/res/worlds/regatta.html and you’ll see that all competitors met the grass challenge equally.
Racing conditions today were lighter than yesterday. The breeze filled in and held relatively steady out of 020 between 5 and 8 knots. The first race of the day got off in good order with an Individual Recall of 2 boats. The six-leg course was 1.0nm long for each leg. Glenn Ashby (AUS 1) and Pete Melvin (USA 69) took first and second with Lars Guck (USA 250) close behind in third. The weather mark was shortened to about 0.8nm for the last leg as the breeze lightened a bit. Race 2 also saw a clean start with 2 OCS boats – one exonerated, on did not (more on this later…). Steady winds kept the course length at 0.85nm for the entire race. The same three competitors took the top three spots, except this time Lars Guck (USA 250) got the bullet, followed by Glenn Ashby (AUS 1) and Pete Melvin (USA 69).
After 4 races it is apparent that there is a real battle for the top. Lars Guck (USA 250) and Glenn Ashby (AUS 1) are tied at the top with 7 points each. Pete Melvin (USA 69) is alone in third with 17 points, Luc DuBois (SUI 202) in fourth with 30 points, and Matt Struble (USA 198) and Mitch Booth (NED 250) tied with 32 points each.
There were a couple of twists in racing today that raised some eyebrows. First was the method being used as a Safety Check as well as a Check-In method for the boats. Each competitor is required to pick up a numbered tag before leaving the beach each morning and are also required to turn the tag back in at the end of each day of racing. Failure to comply with either checking out in the morning or checking in when returning to shore results in a 20% scoring penalty for the first race sailed each day. Yesterday, everyone complied, but today 5 Competitors discovered that there is a zero-tolerance policy when it comes to this procecedure.
The second controversy involved one boat that was called OCS and then requested Redress on the grounds that the RC was late in raising the Individual Recall Flag. After the hearing, the International Jury decided to award Redress points to the competitor even though he admitted at the hearing that he knew he was over early. Based on the facts found, this was what the Jury thought was the appropriate outcome. Needless to say, the Fleet is a tad bit upset with this compromise decision. Sea Lawyers who use the rules to gain an advantage in this manner are never looked on with respect in our sport. It’s unfortunate that this occurrence was even brought up. Oh well, it’s all part of the sport and is even more important at this level of competition.
Looking forward to racing tomorrow, the forecast is for wind much the same as we saw today. Many locals around Islamorada have assured us that the weed/grass issues should be gone by tomorrow, if for no other reason than there is only so much grass that can be washed out of the channels. Let’s hope that’s the case since seeing seaweed snagged on forestays just looks ugly! Once we reach 5 races the throwout kicks in and the results will jumble a bit as the high scores get tossed. We’ve got 4 races on the books with two races scheduled for Wednesday and Thursday and one race on Friday.
More excellent pictures have been uploaded on @N00" target="_blank">http://www.flickr.com/photos/58897601@N00 all taken by Lou Vest. Take some time to check out the excellent pics posted here.
Lastly, but definitely not least, this a great opportunity to recognize the stellar Race Committee that has been put together for this event. Many are volunteers who have been recruited on-site, but there is a core of people who have come here from Texas to provide the World-Class Race Committee that this event deserves. Billy Richnow, the Principal Race Officer, is a long time multihull sailor with many championships under his belt as well as many years organizing and running first class Race Committees. Billy has brought his all star core team with him from Texas. Every one of these folks have years of deep Race Committee experience at this level. On the Signal Boat with Billy are Betty Reeh and Ann Apel. The Pin/Finish boat is managed by Leigh Ann Hawboldt, and the Weather Markset boat is under the able charge of her husband Brian Hawboldt. It would not be possible to execute the on the water racing without both this core crew and the large number of volunteers who make this happen for the 100 Competitors in this World Championship.
http://acatworlds.com/res/worlds/2007_A-Cat_Worlds_Championship.html
Posted : November 14, 2007 12:42 pm
(@brucat)
Thanks again to Rick and Mary, great coverage!!! Thanks for posting that report Tom.
Other than it may not be the norm for cats sailed by adults, there is nothing out of the ordinary about the safety tag procedure. I've seen that exact penalty issued before, and it can be even more harsh than 20% (DSQ).
As for the OCS/RDG, keep in mind that in making a decision to grant redress, the jury has to determine whether the
boat’s score in a race or series has, THROUGH NO FAULT OF HER OWN, been made significantly worse.
Obviously, none of us were there, but with an International Jury involved, I'd like to believe this was taken into consideration.
Mike
Posted : November 14, 2007 1:02 pm
MaryAWells
(@maryawells)
Here's the wrapup on the first race Wednesday, which is the 5th race overall for the regatta:
Positions rounding the weather mark for the third and last time:
1. Pease Glaser
2. Booth
3. Melvin
4. Ashby
5. Guck
6. Ogletree
And Rick's boat went to the finish, because anything could, and did, happen in the light air. Here are the finish positions:
1. Pease Glaser
2. Guck
3. Melvin
4. Ashby
5. Booth
6. Ogletree
7. Daniel
8. Saarberg
9. Cope
10. Kinder
11. Marstrom
12. Randy Smyth
13. Persson
14. Hoekstra
15. Atkins
Rick has done a rough calculation of the overall positions after the five races, taking out a throwout:
1. Guck, 6 points
2. Ashby, 8 points
3. Melvin, 10 points
4. Booth, 25 points
5. Ogletree, 27 points
6. Kinder, 46 points
7. Daniel, 56 points
8. Pease Glaser, 65 points
8. Atkins, 65 points
9. Cope, 71 points
The wind is now down to about 3 knots, and they are going to hold off for a while to see if the wind comes up enough to start another race.
Posted : November 14, 2007 1:17 pm
(@tomsiders)
I will keep posting my reports, but this is great that Rick is there and can get the more timely finishes posted. Rick, Mary, Thank you. You both are great and do tremendous work on all of our behalfs (or should I state benefits). by the way, this is still the best forum out there. Try to navigate catsailor.net the Australian version.
Posted : November 14, 2007 1:38 pm
(@catfan)
Thanks for the explanation.
I was able to understand why Booth was not scored OCS in the 4th race.
But now I wonder why he was given 12 points.
Did he arrive 12th in the fourth race?
Usually a RDG boat is given the average of the points scored in the all races of an event.
Posted : November 14, 2007 2:34 pm
(@edgarapoe)
I noticed several spectator boats rooting against just such a person. No names mentioned here.
Rick
Posted : November 14, 2007 3:29 pm
(@tomsiders)
It seems that if you use the letter of the rules to advance even when you are in the wrong, ie: cross the line early, know that you did and use a redress to stop from recieving an OCS, yeah, that might piss a few fellow competitors off.
Posted : November 14, 2007 3:32 pm
(@rhino1302)
Interesting that back in the
Hobie Race Management
thread Mitch Booth (or someone claiming to be him) climbed on the anti-PU dogpile. Now we see their names together again.
Posted : November 14, 2007 4:16 pm
(@brucat)
I agree, Tom. However, this is all part of the game (as demonstrated by many other threads here for other events in the past).
If the other competitors were convinced that they were right (the sailor in question should have retired), they could have filed a protest when they were made aware of the situation (within the time limit after the results of the protest were posted).
Obviously, this would be heard by the same jury that made the decision to grant redress, so it may not be likely to be upheld, but could be subject to appeal (unless that option is eliminated for the event).
Either way, this stuff is never good for the collective psyche at these events, and can lead to 11:00 pm protests all week, etc. as can be common in Olympics, etc.
Mike
Posted : November 14, 2007 4:21 pm
macca
(@macca)
I read the story of the OCS being turned in to a RDG on the daily sail website, I didn't need to check the results to know who it was....
Posted : November 14, 2007 4:46 pm
(@tomsiders)
Mitch Booth!
The happenings at the beginning of the race is that they posted they postponement flag. If they posted a general recall, then the next start would be under the black flag. There is much more to this story then just that, but I will let somebody else lay that part of the story out.
Posted : November 14, 2007 7:57 pm
