Reynolds 21 vs Stiletto 23
12 Users
41.4 K Views
(@coastrat)
if your gonna be a trailor sailor, pick a boat that is quick to set up. i drive 70 minutes to get to the beach so every minute it takes to set the boat up counts. i can set up my old prindle 16 in under 30 mins, logged over 70 outings over the past 3 seasons...could have upgraded many times but every extra thing cost valuable set up time...if i kept the boat at the club, i would go all out
Posted : November 2, 2011 8:46 pm
(@john5583)
Originally Posted by carlbohannon
If it makes a difference, a version of the Reynold's 21 is in production as the Z21.
http://www.wingzsailboats.com/z21cruisingcatamaran.htm
This means there will be some level of parts support.
I don't know the status of the company. There are questions about them being in buisness.
In looking at thier site I wonder what the Z18P and Z19P are.....Prindle maybe?
Posted : November 3, 2011 7:18 am
(@soulofasailor)
I am on the way to pick mine up! it was Cheap and its my first Multi hull, i needed storage and beachable and fast boat, wanted something high off water also.. This boat looks clean hopefully it matches the pictures when i get there!
Posted : November 3, 2011 10:33 am
(@davefarmer)
Congradulations! Welcome to the club. Keep us posted.....
Posted : November 3, 2011 10:45 am
(@soulofasailor)
if you get a chance subsribe to my YOUTUBE look up jtechie3 i will post a lot of movies soon but there are some out there now.. OH Thanks i will be soon a Multihuler
Any tricks on raisng mast and anything please share I am open to everyones comments!
I take this like camping, you have to put a tent up dont you ,? IT IS WORK?
thanks ALL!
Posted : November 4, 2011 7:29 am
(@davefarmer)
These shots are of the gin pole on Chris Park's Reynolds 21, which has a SC20 mast(33'), and a boom.
The gin pole has a yoke that pins to the the mast thru a hole located at the widest point of the mast. Just forward of that is a standard small boat trailer winch. Chris currently has wire on this one, but I used a 7/16" line for years. This runs fwd to a block just aft of the pole tip.
A vertical slot, just slightly wider than the forestay diameter, is cut in the pole, which lands just above the nico press sleeve that secures the thimble that terminates the forestay.
The winch line terminates in a cast hook with a spring loaded keeper, and this snaps to a s.s. ring at the junction of the 2 bridle wires.
Also attached to the tip of the gin pole are 2 guy lines that clip to the ends of the main beam, stabilizing the pole in the centerline plane.
This system requires that the mast be likewise secured side to side to keep it in that same plane. This boat came with baby stays, attached just below the spreaders, that could be quickly transferred from their fwd chainplates to the beam ends(which have stout s.s loops welded to the end caps). Trapeze wires could work too. Or install something that could be used for this purpose and secured out of the way under sail.
So, with these secured, pin the yoke to the mast, slot the forestay, attach guy lines to beam ends, and clip the winch line to the bridle wires. With the side stays attached to their chainplates, engage the pawl on the winch and crank away. The mast crawls up with no drama, and the gin pole holds it up securely while the loosened forestay turnbuckle is pinned to the ring. Then the winch is released, gin pole removed and forestay turnbuckle tightened.
With all lines properly attached, this is easy and safe. But always be vigilant, the forces are big, and the consequences of mistakes are significant.
One advantage of this system(as opposed to one working off the trailer) is that the mast can be raised and lowered on the water, useful for bridges and negotiating ramps with overhead obstructions. For many years I kept the boat assembled full width on the trailer, and raised and lowered the mast each launch. Took about 10 minutes, up or down.
Posted : November 5, 2011 12:10 am
(@soulofasailor)
Well i have been sailing my Reynolds 21 now for 3 years now.. I have to say i am so glad i picked this boat! I have bout new sails for her last year this year i did a mod to my transom, i do believe i gain 2 knots! <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" /> below is my fix
https://plus.google.com/u/0/113618646846617070054/posts
Posted : June 9, 2014 7:39 pm
(@soulofasailor)
So did anyone else buy a Reynolds ?
Posted : July 10, 2014 8:20 am
Page 2 / 2
