Rolling Auto Paint
8 Users
(@Anonymous 37750)
[#24260]
hmm hmm, gentlemen,
I need to add non skid to the decks of THE BOAT, when I mix the paint should I skip the reducer since I will be rolling and not spraying?
Posted : January 8, 2009 9:30 pm
(@jackflash)
You can use a piece of glass to test consistency before applying. When I did it with two part epoxy auto paint I had to add thinner. How ever in my case I was rolling and tipping and going for a mirrored surface, not doing nonskid. But gut says yes but probably not to the same degree that you would for a mirrored finish.
Posted : January 9, 2009 3:36 am
(@_removed-account)
Four Star Admiral Registered
I used awlgrip non skid on THE OTHER BOAT. The best method was to broadcast after rolling and tipping. The base coat needs to be as strong as possible because it will hold the grit. My guess is that some reducer will help the paint set up strong. For awl-grip I used a sheen killer, and overcoated the grit with more stuff to lock it in. The overcoat should be reduced way down to keep it from filling the grip pits.
Awl-grip extra coarse is wicked rough and terriffic non skid,
Awl-grip medium was great for something you must sit upon
Regards
Chet
Posted : January 9, 2009 9:19 am
(@Fasterdamnit)
Spray on truck bed liner (rattle can).
Posted : January 9, 2009 9:34 am
(@kevin-cook)
here is something you may want to check out; http://www.grizzlygrip.com I bought a quart to to give it a try. Note that the base is a two part linear alphitic urethane - just like Awlgrip and others. Also, the non-skid is ground rubber instead of glass beads or sand.
Kevin`
Posted : January 9, 2009 12:14 pm
(@tcatman)
Hey Kevin
How does your new tri sail? .... She looks great on the hook. Congratulations on the new build!
Mark
Posted : January 9, 2009 1:15 pm
(@Anonymous 39832)
Kevin finished his Tri?!!? Awesome!! I remember checking out his carbon tornado and him showing me a centerboard for it. Amazing shop Kevin has <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
man that seems like decades ago.
Posted : January 9, 2009 2:44 pm
(@Anonymous 37750)
Really, spray on? Does it come in colors other than black?
Posted : January 9, 2009 5:35 pm
Todd A. Hart
(@team_cat_fever)
You've barely been alive
decades
i.e. plural, like two.
Posted : January 9, 2009 6:01 pm
Todd A. Hart
(@team_cat_fever)
Hey Kevin,
How 'bout some pics of your creation. If your gonna race it and need crew gimme a shout.
Todd Hart
Posted : January 9, 2009 6:04 pm
(@Fasterdamnit)
I don't think so, arbo. Wasn't exactly serious. But it would probably work if you don't mind black...
Posted : January 9, 2009 6:55 pm
(@Anonymous 37750)
duhh.
Thanx. Always looking for a shortcut.....
Posted : January 9, 2009 8:17 pm
(@kevin-cook)
It's roll or spray. they have about 20 colors.
Posted : January 9, 2009 9:27 pm
(@kevin-cook)
Hi Mark, Hi Todd,
The new boat works well which is always a shock to me cause I usually try out some new design ideas. The building seemed to go on forever....and ever. I took Greg, Casey, and Onika out and they seemed to like feel of it too. It's fast, well balanced, but not as responsive as the tornado of course.
I was able to rent the same mooring for next season so you guys are welcome to give it a try anytime. I tried to post some pictures on the forum but couldn't get it to work. Tami was able to get one of them up. I'll have to give it another try. Sailing magazine did an interview and a photo shoot but I don't know when or if they will use it. I wish I could get copies of the pictures though - there was one sailing close by Pitate's Cove pier when a big gust hit. Suspect that was a really cool picture. See you in April,
Kevin http://i377.photobucket.com/albums/oo211/kevincook/136.jpg
Posted : January 9, 2009 9:44 pm
(@Anonymous 39832)
Quote
decades
I know that counting to three is difficult for you, but thats the number of decades that I've nearly been around.
Posted : January 10, 2009 9:13 am
Todd A. Hart
(@team_cat_fever)
Quote
decades
nearly
That's funny. My 7 year old does that too.
Posted : January 10, 2009 9:30 am
(@stank)
One Star Admiral Registered
I'd think that bedliner spray might be a bit on the heavy side, but maybe it's because they spray it on thick...
Why not just apply the two-part coating on as usual, and dust with sugar crystals before it sets? Then you can wash off the sugar after it's dry (the sugar dissolves, leaving the rough surface) for the non-skid??
Surf board builders call it
sugar deck
A courser finish could be had using Kosher salt or unrefined sugar (
sugar in the raw
Posted : January 12, 2009 10:23 am
(@Anonymous 37750)
I have the Pettit skidless compound onhand. My concern is that I want to get even distribution of the material. The material will settle to the bottom of the tray or container. Skould I put it in a salt shaker or add it to the paint and mix often?
Posted : January 12, 2009 7:56 pm
